Hello!
I am using ArcGIS Pro 2.0 to digitize (COGO) some large areas of land. I have set the project's units to DMS and Quadrant Bearings in the Options.
Problem: Although the digitization is working as intended, I noticed that the Direction field in the attributes table gets entered in north azimuth format. I'd like to be able to label the boundary bearings to match the survey map, which is in DMS format.
TLDR: In ArcMap, COGO writes direction field in DMS format; is it possible to have the direction field attribute set to DMS in ArcGIS Pro?
Thanks in advance!
