Confused here...working on integrating a couple examples...one references map and the other one app.maphttps://developers.arcgis.com/javascript/jssamples/widget_print_esri_request.htmlapp.map = new esri.Map("map", { basemap: "hybrid", center: [-117.447, 33.906], zoom: 17, slider: false });
https://developers.arcgis.com/javascript/jssamples/widget_basemap.htmlmap = new Map("map", { basemap: "topo", center: [-105.255, 40.022], zoom: 13 });
I have the example with app.map working () but I then try and bring in the Basemap gallery and that one only has map referenced...how do I modify this to workTHE basemap selector appears but when I select a map nothing happens.I tried this var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, app.map: map }, "basemapGallery"); basemapGallery.startup();
var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); });
var map; var app = {}; require([ "dojo/ready", "dojo/on", "dojo/_base/connect", "dojo/dom", "dojo/dom-construct", "dojo/parser", "dijit/registry", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/InfoTemplate", "esri/renderers/UniqueValueRenderer", "esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "esri/map", "esri/dijit/BasemapGallery", "esri/request", "esri/config", "dojo/_base/array", "esri/dijit/Print", "esri/tasks/PrintTemplate", "esri/arcgis/utils", "esri/domUtils", "esri/dijit/Popup", "dojo/domReady!" ], function( ready, on, connect, dom, domConstruct, parser, registry, FeatureLayer, ArcGISDynamicMapServiceLayer, InfoTemplate, UniqueValueRenderer, SimpleRenderer, SimpleMarkerSymbol, SimpleLineSymbol, BorderContainer, ContentPane, Map, BasemapGallery, esriRequest, esriConfig, arrayUtils, Print, PrintTemplate, arcgisUtils, domUtils, Popup ) { //ready(function(){ parser.parse(); //setup event handlers for the next/previous buttons on(dom.byId("previous"), "click", selectPrevious); on(dom.byId("next"), "click", selectNext); esri.config.defaults.io.proxyUrl = "https://junk.gov/proxypage_net/proxy.ashx"; app.map = new esri.Map("map", { basemap: "topo", center: [-77.4329, 37.5410], zoom: 7, slider: false }); // add graphics for pools with permits var permitUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/MapServer/1"; var poolFeatureLayer = new FeatureLayer(permitUrl, { mode: FeatureLayer.MODE_SNAPSHOT }); app.map.addLayer(poolFeatureLayer); var TestUrl2 = "https://map.gov/arcgis/rest/services/Map/Map_Readonly/FeatureServer/0"; var FeatureLayer2 = new FeatureLayer(TestUrl2, { mode: FeatureLayer.MODE_SNAPSHOT }); app.map.addLayer(FeatureLayer2); //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); });
