esri|PopUpRenderer { skin-class: ClassReference("com.esri.viewer.skins.PopUpRendererSkin"); }
// My addition for highlighting popup features... var glExists:Boolean = false; var glID:int; //Go through layerIds in map to check if the highlightGraphics graphiclayer exists and if so get its id. for (var i:int = 0; i < map.layerIds.length; i++) { if (map.layerIds== "highlightGraphics") { glID = i; glExists = true; } } //If highlightGraphics graphicslayer doesn't exist, create it and add it to the map. if(!glExists){ var gl:GraphicsLayer = new GraphicsLayer(); gl.id = "highlightGraphics"; gl.visible = true; map.addLayer(gl,200); //Get the id of the graphicslayer for (var j:int = 0; j < map.layerIds.length; j++) { if (map.layerIds== "highlightGraphics") { glID = j; glExists = true; } } } //Set the highlight graphic symbol var hlGraphic:Graphic = new Graphic(graphic.geometry); switch(hlGraphic.geometry.type) { case Geometry.MAPPOINT: { hlGraphic.symbol = new SimpleMarkerSymbol("circle",22,0x000000,0,0,0,0,new SimpleLineSymbol("solid",0xFF0000,0.5,2)); break; } case Geometry.POLYLINE: { hlGraphic.symbol = new SimpleLineSymbol("solid",0xFF0000,0.3,8); break; } default: { hlGraphic.symbol = new SimpleFillSymbol("solid",0x000000,0,new SimpleLineSymbol("solid",0xFF0000,0.4,3)); break; } } //set a glow filter to the highlight graphic var gf:spark.filters.GlowFilter = new spark.filters.GlowFilter(); gf.color = 0xFF0000; gf.alpha = 1; gf.strength = 2; gf.blurX = 8; gf.blurY = 8; hlGraphic.filters = [gf]; //Clear the highlightGraphics graphiclayer and add the new highight graphic map.layers[glID].clear(); map.layers[glID].add(hlGraphic); //add eventhandlers to "unhighlight" features map.infoWindow.closeButton.addEventListener(MouseEvent.CLICK, onInfoWindowClosed); map.addEventListener(MapMouseEvent.MAP_CLICK, onMapClick) // --- end addition ---------------
//My handler for clicking closebutton on a popup/infowindow private function onInfoWindowClosed(event:MouseEvent):void { if(hostComponent.map){ for (var i:int = 0; i < hostComponent.map.layerIds.length; i++) { if (hostComponent.map.layerIds== "highlightGraphics") { hostComponent.map.layers.clear(); } } hostComponent.map.infoWindow.closeButton.removeEventListener(MouseEvent.CLICK, onInfoWindowClosed); } } //My handler for a mapclick, mapclicking outside a feature with popup configuration will hide popup/infowindow and clear the highlight graphics. private function onMapClick(event:MapMouseEvent):void { for (var i:int = 0; i < event.map.layerIds.length; i++) { if (event.map.layerIds== "highlightGraphics") { event.map.layers.clear(); } } event.map.infoWindow.hide(); event.map.removeEventListener(MapMouseEvent.MAP_CLICK, onMapClick); }
