I took too much time trying to find the assembly so i decided to implement a method for reading and writing shape files myself.....was surprisingly easy! If anyone wishes some simple code snippets for help just ask 🙂Thanks for the help!
public enum ShapeType    {        NullShape,        Point, PolyLine, Polygon, MultiPoint,        PointZ, PolyLineZ, PolygonZ, MultiPointZ,        PointM, PolyLineM, PolygonM, MultiPointM,        MultiPatch,        Unknown    };    public class ShapeFile    {        public static ShapeType[] SupportedShapes = new ShapeType[] { ShapeType.PolyLine, ShapeType.Point };        public ShapeType ShapeType;        public int FileLength;        public int Version;        public int FileCode;        public BoundingBox Boundary;        public List<VectorShape> Data = new List<VectorShape>();        public void Read(String ShapeFile )        {            FileStream Stream = new FileStream(ShapeFile, FileMode.Open);            BinaryReader Reader = new BinaryReader(Stream);            FileCode = (int) ReverseBytes((UInt32)Reader.ReadInt32());            if (FileCode != 9994)                throw new IOException("The Input file specified is not a valid Shape File (Invalid FileCode)");            //read empty bytes found in the file            Reader.ReadBytes(20);            FileLength = (int) ReverseBytes((UInt32)Reader.ReadInt32());            Version = Reader.ReadInt32();            ShapeType = GetShapeType(Reader.ReadInt32());            if (ShapeType == ShapeType.Unknown)                throw new IOException("The Input file has an unknown Shape Type Specified");            if (!SupportedShapes.Contains(ShapeType))                throw new IOException("The Input file has a shape type that is not suppored (" + ShapeType + ")\n" +                                      "The Following types are supported:\n" +                                      SupportedShapes);            Boundary = new BoundingBox();            Boundary.XMin = Reader.ReadDouble();            Boundary.YMin = Reader.ReadDouble();            Boundary.XMax = Reader.ReadDouble();            Boundary.YMax = Reader.ReadDouble();            Boundary.ZMin = Reader.ReadDouble();            Boundary.ZMax = Reader.ReadDouble();            Boundary.MMin = Reader.ReadDouble();            Boundary.MMax = Reader.ReadDouble();            while (Stream.Position < FileLength)            {                int RecordNumber = (int)ReverseBytes((UInt32)Reader.ReadInt32());                int ContentLength = (int)ReverseBytes((UInt32)Reader.ReadInt32());                ShapeType RecordShapeType = GetShapeType( Reader.ReadInt32() );                switch( RecordShapeType )                {                    case ShapeType.Point: Data.Add(ReadPoint(Reader)); break;                    case ShapeType.PolyLine: Data.Add(ReadPolyLine(Reader)); break;                }            }            Stream.Close();        }        public void Write(String ShapeFile)        {            FileStream Stream = new FileStream(ShapeFile, FileMode.Create);            BinaryWriter Writer = new BinaryWriter(Stream);            Writer.Write( ReverseBytes(9994) );    //filecode            Writer.Seek(28, 0);                    //file length            Writer.Write( (int) 1000);             //Version            Writer.Write(GetShapeCode(ShapeType));            Writer.Write(Boundary.XMin);            Writer.Write(Boundary.YMin);            Writer.Write(Boundary.XMax);            Writer.Write(Boundary.YMax);            Writer.Write(Boundary.ZMin);            Writer.Write(Boundary.ZMax);            Writer.Write(Boundary.MMin);            Writer.Write(Boundary.MMax);            for (int i = 0; i < Data.Count; i++)            {                Writer.Write((int)ReverseBytes((UInt32)i));                Writer.Write((int)ReverseBytes((UInt32)Data.SizeOf()));      //content length                if (Data is PolyLine)                {                    Writer.Write(GetShapeCode(ShapeType.PolyLine));                    WritePolyline(Writer, (PolyLine) Data );                }                if (Data is Point )                {                    Writer.Write(GetShapeCode(ShapeType.Point));                    WritePoint(Writer, (Point) Data );                }            }            int FileLength = (int) Stream.Position;            Writer.Seek(24,0);            Writer.Write((int)ReverseBytes((UInt32)FileLength));            Stream.Close();        }        private void WritePoint(BinaryWriter Writer, Point Point)        {            Writer.Write(Point.X);            Writer.Write(Point.Y);        }        private Point ReadPoint(BinaryReader Reader)        {            Point Point = new Point();            Point.X = Reader.ReadDouble();            Point.Y = Reader.ReadDouble();            return Point;        }        private void WritePolyline(BinaryWriter Writer, PolyLine PolyLine)        {            Writer.Write(PolyLine.XMin);            Writer.Write(PolyLine.YMin);            Writer.Write(PolyLine.XMax);            Writer.Write(PolyLine.YMax);            Writer.Write(PolyLine.NumParts);            Writer.Write(PolyLine.NumPoints);            for (int i = 0; i < PolyLine.NumParts; i++ )                Writer.Write( PolyLine.Parts );            for (int i = 0; i < PolyLine.NumPoints; i++)                WritePoint(Writer, PolyLine.Points);        }        private PolyLine ReadPolyLine(BinaryReader Reader)        {            PolyLine Output = new PolyLine();            Output.XMin = Reader.ReadDouble();            Output.YMin = Reader.ReadDouble();            Output.XMax = Reader.ReadDouble();            Output.YMax = Reader.ReadDouble();            Output.NumParts = Reader.ReadInt32();            Output.NumPoints = Reader.ReadInt32();            Output.Parts = new int[Output.NumParts];            Output.Points = new Point[Output.NumPoints];            for (int i = 0; i < Output.Parts.Length; i++)                Output.Parts = Reader.ReadInt32();            for (int i = 0; i < Output.Points.Length; i++)                Output.Points = ReadPoint(Reader);            return Output;        }        public static UInt32 ReverseBytes(UInt32 value)        {            return (value & 0x000000FFU) << 24 | (value & 0x0000FF00U) << 8 |                   (value & 0x00FF0000U) >> 8 | (value & 0xFF000000U) >> 24;        }        public static int GetShapeCode(ShapeType Type)        {            switch (Type)            {                case ShapeType.NullShape : return 0;                case ShapeType.Point: return 1;                case ShapeType.PolyLine : return 3;                case ShapeType.Polygon: return 5;                case ShapeType.MultiPoint: return 8;                case ShapeType.PointZ: return 11;                case ShapeType.PolyLineZ: return 13;                case ShapeType.PolygonZ: return 15;                case ShapeType.MultiPointZ: return 18;                case ShapeType.PointM: return 21;                case ShapeType.PolyLineM : return 23;                case ShapeType.PolygonM : return 25;                case ShapeType.MultiPointM: return 28;                case ShapeType.MultiPatch: return 31;                default :return -1;            }        }        public static ShapeType GetShapeType(int Code)        {            switch (Code)            {                case 0: return ShapeType.NullShape;                case 1: return ShapeType.Point;                case 3: return ShapeType.PolyLine;                case 5: return ShapeType.Polygon;                case 8: return ShapeType.MultiPoint;                case 11: return ShapeType.PointZ;                case 13: return ShapeType.PolyLineZ;                case 15: return ShapeType.PolygonZ;                case 18: return ShapeType.MultiPointZ;                case 21: return ShapeType.PointM;                case 23: return ShapeType.PolyLineM;                case 25: return ShapeType.PolygonM;                case 28: return ShapeType.MultiPointM;                case 31: return ShapeType.MultiPatch;                default: return ShapeType.Unknown;            }        }
Can you please send me the code?
public enum ShapeType    {        NullShape,        Point, PolyLine, Polygon, MultiPoint,        PointZ, PolyLineZ, PolygonZ, MultiPointZ,        PointM, PolyLineM, PolygonM, MultiPointM,        MultiPatch,        Unknown    };    public class ShapeFile    {        public static ShapeType[] SupportedShapes = new ShapeType[] { ShapeType.PolyLine, ShapeType.Point };        public ShapeType ShapeType;        public int FileLength;        public int Version;        public int FileCode;        public BoundingBox Boundary;        public List<VectorShape> Data = new List<VectorShape>();        public void Read(String ShapeFile )        {            FileStream Stream = new FileStream(ShapeFile, FileMode.Open);            BinaryReader Reader = new BinaryReader(Stream);            FileCode = (int) ReverseBytes((UInt32)Reader.ReadInt32());            if (FileCode != 9994)                throw new IOException("The Input file specified is not a valid Shape File (Invalid FileCode)");            //read empty bytes found in the file            Reader.ReadBytes(20);            FileLength = (int) ReverseBytes((UInt32)Reader.ReadInt32());            Version = Reader.ReadInt32();            ShapeType = GetShapeType(Reader.ReadInt32());            if (ShapeType == ShapeType.Unknown)                throw new IOException("The Input file has an unknown Shape Type Specified");            if (!SupportedShapes.Contains(ShapeType))                throw new IOException("The Input file has a shape type that is not suppored (" + ShapeType + ")\n" +                                      "The Following types are supported:\n" +                                      SupportedShapes);            Boundary = new BoundingBox();            Boundary.XMin = Reader.ReadDouble();            Boundary.YMin = Reader.ReadDouble();            Boundary.XMax = Reader.ReadDouble();            Boundary.YMax = Reader.ReadDouble();            Boundary.ZMin = Reader.ReadDouble();            Boundary.ZMax = Reader.ReadDouble();            Boundary.MMin = Reader.ReadDouble();            Boundary.MMax = Reader.ReadDouble();            while (Stream.Position < FileLength)            {                int RecordNumber = (int)ReverseBytes((UInt32)Reader.ReadInt32());                int ContentLength = (int)ReverseBytes((UInt32)Reader.ReadInt32());                ShapeType RecordShapeType = GetShapeType( Reader.ReadInt32() );                switch( RecordShapeType )                {                    case ShapeType.Point: Data.Add(ReadPoint(Reader)); break;                    case ShapeType.PolyLine: Data.Add(ReadPolyLine(Reader)); break;                }            }            Stream.Close();        }        public void Write(String ShapeFile)        {            FileStream Stream = new FileStream(ShapeFile, FileMode.Create);            BinaryWriter Writer = new BinaryWriter(Stream);            Writer.Write( ReverseBytes(9994) );    //filecode            Writer.Seek(28, 0);                    //file length            Writer.Write( (int) 1000);             //Version            Writer.Write(GetShapeCode(ShapeType));            Writer.Write(Boundary.XMin);            Writer.Write(Boundary.YMin);            Writer.Write(Boundary.XMax);            Writer.Write(Boundary.YMax);            Writer.Write(Boundary.ZMin);            Writer.Write(Boundary.ZMax);            Writer.Write(Boundary.MMin);            Writer.Write(Boundary.MMax);            for (int i = 0; i < Data.Count; i++)            {                Writer.Write((int)ReverseBytes((UInt32)i));                Writer.Write((int)ReverseBytes((UInt32)Data.SizeOf()));      //content length                if (Data is PolyLine)                {                    Writer.Write(GetShapeCode(ShapeType.PolyLine));                    WritePolyline(Writer, (PolyLine) Data );                }                if (Data is Point )                {                    Writer.Write(GetShapeCode(ShapeType.Point));                    WritePoint(Writer, (Point) Data );                }            }            int FileLength = (int) Stream.Position;            Writer.Seek(24,0);            Writer.Write((int)ReverseBytes((UInt32)FileLength));            Stream.Close();        }        private void WritePoint(BinaryWriter Writer, Point Point)        {            Writer.Write(Point.X);            Writer.Write(Point.Y);        }        private Point ReadPoint(BinaryReader Reader)        {            Point Point = new Point();            Point.X = Reader.ReadDouble();            Point.Y = Reader.ReadDouble();            return Point;        }        private void WritePolyline(BinaryWriter Writer, PolyLine PolyLine)        {            Writer.Write(PolyLine.XMin);            Writer.Write(PolyLine.YMin);            Writer.Write(PolyLine.XMax);            Writer.Write(PolyLine.YMax);            Writer.Write(PolyLine.NumParts);            Writer.Write(PolyLine.NumPoints);            for (int i = 0; i < PolyLine.NumParts; i++ )                Writer.Write( PolyLine.Parts );            for (int i = 0; i < PolyLine.NumPoints; i++)                WritePoint(Writer, PolyLine.Points);        }        private PolyLine ReadPolyLine(BinaryReader Reader)        {            PolyLine Output = new PolyLine();            Output.XMin = Reader.ReadDouble();            Output.YMin = Reader.ReadDouble();            Output.XMax = Reader.ReadDouble();            Output.YMax = Reader.ReadDouble();            Output.NumParts = Reader.ReadInt32();            Output.NumPoints = Reader.ReadInt32();            Output.Parts = new int[Output.NumParts];            Output.Points = new Point[Output.NumPoints];            for (int i = 0; i < Output.Parts.Length; i++)                Output.Parts = Reader.ReadInt32();            for (int i = 0; i < Output.Points.Length; i++)                Output.Points = ReadPoint(Reader);            return Output;        }        public static UInt32 ReverseBytes(UInt32 value)        {            return (value & 0x000000FFU) << 24 | (value & 0x0000FF00U) << 8 |                   (value & 0x00FF0000U) >> 8 | (value & 0xFF000000U) >> 24;        }        public static int GetShapeCode(ShapeType Type)        {            switch (Type)            {                case ShapeType.NullShape : return 0;                case ShapeType.Point: return 1;                case ShapeType.PolyLine : return 3;                case ShapeType.Polygon: return 5;                case ShapeType.MultiPoint: return 8;                case ShapeType.PointZ: return 11;                case ShapeType.PolyLineZ: return 13;                case ShapeType.PolygonZ: return 15;                case ShapeType.MultiPointZ: return 18;                case ShapeType.PointM: return 21;                case ShapeType.PolyLineM : return 23;                case ShapeType.PolygonM : return 25;                case ShapeType.MultiPointM: return 28;                case ShapeType.MultiPatch: return 31;                default :return -1;            }        }        public static ShapeType GetShapeType(int Code)        {            switch (Code)            {                case 0: return ShapeType.NullShape;                case 1: return ShapeType.Point;                case 3: return ShapeType.PolyLine;                case 5: return ShapeType.Polygon;                case 8: return ShapeType.MultiPoint;                case 11: return ShapeType.PointZ;                case 13: return ShapeType.PolyLineZ;                case 15: return ShapeType.PolygonZ;                case 18: return ShapeType.MultiPointZ;                case 21: return ShapeType.PointM;                case 23: return ShapeType.PolyLineM;                case 25: return ShapeType.PolygonM;                case 28: return ShapeType.MultiPointM;                case 31: return ShapeType.MultiPatch;                default: return ShapeType.Unknown;            }        }        public override string ToString()        {            return "Version = " + Version + ", FileLength = " + FileLength + ", FileCode = " + FileCode + ", ShapeType = " + ShapeType + ", Boundary = " + Boundary;        }    }
i seem to recall being able to download the compiled assembly, but you're right, it's not there any more. it looks like you'll need to download the source code and compile it yourself.
http://esrislcontrib.codeplex.com/
