When I monitor the http calls
I am using secure services by the way.
Why would I be able to display the polygon and line symbology but not the point symbology, with or without the proxy?
Has anyone found a solution to this IE8 issue? I am having the same trouble trying to display a featureLayer that are points (polygons and lines work like they should). I am getting all of the data returned from the server but all that is being displayed is a hollow square in place of the point symbol. I am using simple points. I have tried the solutions found here but none work. Everything works as it should in IE9, Firefox or Chrome.
function fixIELayers(evt) { // IE FIX FOR IMAGES NOT SHOWING IN FEATURE LAYER!!! if (dojo.isIE) { var currentLayer = Hydrants; //map.getLayer(map.layerIds); if(currentLayer && currentLayer.renderer && currentLayer.renderer.infos) { for (var i=0; i<currentLayer.renderer.infos.length; i++) { var url1=currentLayer.renderer.infos.symbol.url; var url2=esri.config.defaults.io.proxyUrl+'?'; if (url1.indexOf(url2) != -1) continue; var url3=url2+url1; currentLayer.renderer.infos.symbol.url = url3; } }else if(currentLayer && currentLayer.renderer && currentLayer.renderer.symbol) { var url1=currentLayer.renderer.symbol.url; var url2=esri.config.defaults.io.proxyUrl+'?'; if (url1.indexOf(url2) == -1) { var url3=url2+url1; currentLayer.renderer.symbol.url = url3; } } } }
function init() { // called with dojo.onLoad // `map` is the main map with basemap both already set.... dojo.connect(map, "onLoad", function() { template = new esri.InfoTemplate(); template.setTitle("mytitle"); template.setContent(getTextContent); var HGLayerURL2 = [myfeaturelayer's url]; // note that below i don't declare the HGLayerMap - it is already declared outside this function HGLayerMap = new esri.layers.FeatureLayer(HGLayerURL2, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, infoTemplate:template, outFields: [list of my fields hrere...] }); map.addLayer(HGLayerMap); dojo.connect(map,"onUpdateStart",function(){ // some of my code comes here... fixIELayers(); // the fixer... }); // some more code here..... }); return true; } // end of init() dojo.addOnLoad(init); // END INIT PART! function fixIELayers(evt) { // IE FIX FOR IMAGES NOT SHOWING IN FEATURE LAYER!!! if (dojo.isIE) { var currentLayer = HGLayerMap; //map.getLayer(map.layerIds); if(currentLayer && currentLayer.renderer && currentLayer.renderer.infos) { for (var i=0; i<currentLayer.renderer.infos.length; i++) { var url1=currentLayer.renderer.infos.symbol.url; var url2=esri.config.defaults.io.proxyUrl+'?'; if (url1.indexOf(url2) != -1) continue; var url3=url2+url1; currentLayer.renderer.infos.symbol.url = url3; } } } }
I had same problem, this is what I have made:Basicaly the IE gets wrong url without proxy, you have to add it manually. dojo.forEach(layers, function(layer) { if (dojo.isIE) { if(layer.renderer.infos){ for (var i=0; i<layer.renderer.infos.length; i++){ var url1=layer.renderer.infos.symbol.url;// alert(url1); var url2="http://"+server+"/proxy.jsp?";// alert(url2); var url3=url2+url1; layer.renderer.infos.symbol.url=url3; } } }worked for me
Dear ArcGIS Javascript API Team,I have configured a secured MapService with a single layer (Picture Marker Symbol) using the proxy page from Esri.I have configured everything as told on the Javascript documentation about the proxy and if I use the mapservice as an ArcGISDynamicMapService it works fine and the proxy is triggered correctly.When I create a FeatureLayer pointing to the map service layer and add it to the map, I have realized that Internet Explorer 8 or 9 cannot show the images (Base64). The proxy page is being triggered and I believe is missing something in the response code.Google Chrome shows perfectly well all symbology.Can please someone provide me guidance on this?Cheers,José Sousa
