I wanted to know if it was possible to make a voting application with Appstudio, retrieve the data and display it on a dashboard...
Hi @gareth walter, I hope you found a solution, I also modified the code of my application by adding the url of my Survey123 form but nothing changes. The application opens with the Survey gallery
Hi Dambé SANWOGOU,
Before going down the development path, have you seen the public surveys in Survey123? If you have and that doesn't fit your need, I would suggest that you start with the Quick Report. This will allow you set up your questions/fields in the feature service and away you go.
Good luck,
Gareth
