Hi, I have a group of users all accessing data from geodatabases on a shared network drive. I've noticed that if someone copies or moves an aprx file to another folder on the network, all data links are broken. it's like ArcGIS pro is expecting relative paths by default, and resets all data paths to the new directory. is it possible to have an ArcGIS pro project keep the source data paths the same when the project is moved? the only workaround is to "save as" to the new directory, but often users want to simply move projects using windows explorer. thanks
