esri.config.defaults.io.proxyUrl = "http://<yourservername>/proxy.ashx";
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Edit Water Crossings</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" /> <style> html,body{height:100%;width:100%;margin:0;overflow:hidden;} #map{ padding:0; } #header{ font-size:14pt; padding-left:20px; padding-top:4px; color:#660000; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} .esriAttributeInspector {height:500px; width: 450px;} .esriAttributeInspector .atiField {width: 250px;} </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); var map; function init() { esri.config.defaults.io.proxyUrl = "http://<yourservername>/proxy.ashx"; var startExtent = new esri.geometry.Extent(2300000, 7300000, 2830000, 7700000, new esri.SpatialReference({ wkid: 2036 })); map = new esri.Map("map", { extent: startExtent, slider: false }); dojo.connect(map, "onLayersAddResult", initEditor); var baseMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer"); map.addLayer(baseMapLayer); var watercourse = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/6", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([watercourse]); } function initEditor(results) { var templateLayers = dojo.map(results, function (result) { return result.layer; }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: 'auto', columns: 3, }, 'templateDiv'); templatePicker.startup(); var layers = dojo.map(results, function (result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true }; var params = { settings: settings }; var myEditor = new esri.dijit.editing.Editor(params, 'editorDiv'); map.infoWindow.resize(500, 500); myEditor.startup(); } dojo.ready(init); </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit.layout.ContentPane" id="header" data-dojo-props="region:'top'"> Watercross Edit </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="editorDiv"></div> </div> <div data-dojo-type="dijit.layout.ContentPane" id="map" data-dojo-props="region:'center'"></div> </div> </body> </html>
<ProxyConfig mustMatch="false">
columns: 3,
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Edit Water Crossings</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" /> <style> html,body{height:100%;width:100%;margin:0;overflow:hidden;} #map{ padding:0; } #header{ font-size:14pt; padding-left:20px; padding-top:4px; color:#660000; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} .esriAttributeInspector {height:500px; width: 450px;} .esriAttributeInspector .atiField {width: 250px;} </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); var map; function init() { var startExtent = new esri.geometry.Extent(2300000, 7300000, 2830000, 7700000, new esri.SpatialReference({ wkid: 2036 })); map = new esri.Map("map", { extent: startExtent, slider: false }); dojo.connect(map, "onLayersAddResult", initEditor); var baseMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://edmsnt007:6080/arcgis/rest/services/Standard_Base_Map_Service/MapServer"); map.addLayer(baseMapLayer); var watercourse = new esri.layers.FeatureLayer("http://edmsnt007:6080/arcgis/rest/services/Watercross_Edit/FeatureServer/0", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([watercourse]); } function initEditor(results) { var templateLayers = dojo.map(results, function (result) { return result.layer; }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: 'auto', columns: 3, }, 'templateDiv'); templatePicker.startup(); var layers = dojo.map(results, function (result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true }; var params = { settings: settings }; var myEditor = new esri.dijit.editing.Editor(params, 'editorDiv'); map.infoWindow.resize(500, 500); myEditor.startup(); } dojo.ready(init); </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit.layout.ContentPane" id="header" data-dojo-props="region:'top'"> Watercross Edit </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="editorDiv"></div> </div> <div data-dojo-type="dijit.layout.ContentPane" id="map" data-dojo-props="region:'center'"></div> </div> </body> </html>
I have a simple Javascript API that uses the editor widget. It works fine in Google Chome but in IE 9 I cannot create new features, update attributes, or add attachments. Why would this be?
