My website is not filling the screen. My CSS sets the html and body to a height of 100%. On top of that my dojo grid is not displaying with the correct CSS. Anyone have any ideas on why either of those don't display correctly?[HTML]<!DOCTYPE HTML><html><head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title>Text Search</title> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <script> var dojoConfig = { parseOnLoad:true }; </script> <script src="http://js.arcgis.com/3.6/"></script> <script src="Scripts/App2.js"></script> <script> dojo.require("dojox.grid.DataGrid"); </script> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/tundraGrid.css"> <link rel="stylesheet" href="Styles/Base.css"> <style> </style></head><body class="tundra"><div id="titleBar"><div id="titleText" class="mapMenus"> <a href='http://azogcc.az.gov/'>ARIZONA OIL AND GAS <br>CONSERVATION COMMISSION</a></div><div id="navigationMenu" class="mapMenus"> <ul> <li><a href='http://azogcc.az.gov/'>Home</a></li> <li><a href='http://azgs.az.gov/'>AZGS</a></li> <li><a href='http://welldata.azogcc.az.gov/index.html'>Map Search</a></li> <li><a href='http://welldata.azogcc.az.gov/PyCh_index.html'>Text Search</a></li> </ul></div> <div id="titleImg" class="mapMenus"> <a href='http://azgs.az.gov/'><img src="photos/AZ_state_seal2.png" height="49" width="49"></a> </div></div><div id="search_info" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'"> <p> <span id="TextSearch"><strong>Text Search:</strong></span> Complete one or multiple fields and press the Submit Search button to search for wells based on their attributes. Selecting LAS data will open the LAS data in a text file. The selected LAS data can be saved and downloaded by using the save page as function. </p> </div><div id="search_body" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width: 100%; height: 100%; margin: 0;"><div id="image_box" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <image src="photos/Arizona_Meridians_Labled.jpg" height="385" width="350"> <div id="img_info"> <p>Map of Arizona State Meridians</p> </div> </image></div><div id="forum" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> <form action=""> <table> <tr> <td class="label"> <label for="apinum">API Number</label> </td> <td> <input type="text" name="apino" id="apinum" size="14" maxlength="14" placeholder="02-005-00000"><br> </td> </tr> <tr> <td> <input type="button" id="executeApi" value="Search by API"/> </td> </tr> </table> </form></div><div id="outGrid" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: bottom"> <!-- https://developers.arcgis.com/en/javascript/jssamples/fl_paging.html --> <table data-dojo-type="dojox.grid.DataGrid" escapeHTMLInData="false" jsid="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'" style="height:100%; width:100%"> <thead> <tr> <th field="apino" width="auto">API No</th> <th field="otherid" width="auto">State Permit No</th> <th field="wellname" width="auto">Operator</th> <th field="county" width="auto">County</th> <th field="twp" width="auto">Township</th> <th field="rge" width="auto">Range</th> <th field="section_" width="auto">Section</th> <th field="drillertotaldepth" width="auto">Depth (ft)</th> <th field="formationtd" width="auto">Formation at Depth</th> <th field="folderField" width="auto" >Well Folder</th> <th field="logField" width="auto" >Scanned Well Log</th> <th field="lasField" width="auto" >LAS Data</th> </tr> </thead> </table></div></div></body></html>[/HTML]
require(["dojo/data/ObjectStore",
"dijit/registry",
"dojo/store/Memory",
"dgrid/OnDemandGrid",
"dojo/ready",
"esri/tasks/query",
"esri/tasks/QueryTask",
"dojo/dom",
"dojo/on",
"dojo/_base/array",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"],
function(ObjectStore,
registry,
Memory,
Grid,
ready,
Query,
QueryTask,
dom,
on,
array){
ready(function(){
var myQueryTask, myQuery;
myQueryTask = new QueryTask("http://.../ArcGIS/rest/services/aasggeothermal/AZWellHeaders/MapServer/0");
myQuery = new Query();
myQuery.returnGeometry = false;
myQuery.outFields = ["apino","otherid","wellname","county","twp","rge","section_","drillertotaldepth","formationtd","field","relatedresource","welltype"];
function runQuery(){
var apiNo = dom.byId('apinum').value;
var otherId = dom.byId('stateperm').value;
var wellName = dom.byId('wellnameid');
var county = dom.byId('countyid');
var twp = dom.byId('twpid');
var rge = dom.byId('rgeid');
var section = dom.byId('sectionid');
var drillerDepth = dom.byId('depthid');
var formation = dom.byId('formationtdid');
var field = dom.byId('fieldid');
myQuery.where ="apino like '%" + apiNo + "%'" + " OR " + "otherid like '%" + otherId + "%'";
myQueryTask.execute(myQuery,updateGrid);
function apiQuery(){
myQuery.where ="apino like '%" + apiNo + "%'";
on(dom.byId("executeApi"), "click", apiQuery);
[ATTACH=CONFIG]27747[/ATTACH]
