Hello again, I'm still encountering this issue of the address locator / geocoding tool giving high scores (even 100) to addresses matched in the wrong zip code. If possible I would have these matches receive a score of zero as they are incorrect. I am running ArcGIS v10.0 (Build 3200) with SP2. All patches are installed including the "geocoding memory leak" patch.Also, when building an address locator from TeleAtlas street data, the geocoding service will use the zipcode field to some extent, but will still place very high scores (>95) for matches in the wrong postal boundary. I have to run a spatial join on a postal boundary layer and do a select by attributes to find the matches in the correct zip codes, which always eliminates over 95% of the matches.Also, the process seems to place low priority to Suffix and Prefix Type. An address of "12th St" will be matched with "12th Ave" and be given a very high score (>90). Also "N 12th St" will be matched with "S 12th St" with a high score (>90). Basically it seems the only field the address locator places any weight to is the street name and civic number. By the way I am not using composite locators of any kind.Has this issue been resolved? Is there a way to force the address locator to use these fields to validate a match? The geocoding functions worked wonderfully in 9.3.1 which makes this a real shame.*EDIT* I have imported the address locators from 9.3.1 and am experiencing the same issues.
