I am trying to read a FC geometry which has one record in it
Grab this geometry and use it in an INSERT cursor with specific attributes
Think I am close but cant get the geometry of the FCs feature...the FC has only one....
geometries <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Counties_3_dissolved'</SPAN><SPAN class="punctuation token">,</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
length <SPAN class="operator token">=</SPAN> sum<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>g<SPAN class="punctuation token">.</SPAN>length <SPAN class="keyword token">for</SPAN> g <SPAN class="keyword token">in</SPAN> geometries<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Total length: {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>length<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token"># Create a feature class </SPAN>
result1 <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>CreateFeatureclass<SPAN class="punctuation token">(</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>scratchGDB<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri_square"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"POLYGON"</SPAN><SPAN class="punctuation token">,</SPAN> spatial_reference<SPAN class="operator token">=</SPAN><SPAN class="number token">26917</SPAN><SPAN class="punctuation token">)</SPAN>
feature_class <SPAN class="operator token">=</SPAN> result1<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
inputFeatureclass <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Data\SelectCounties.gdb\Counties_4_final_append"</SPAN>
<SPAN class="comment token"># Write feature to new feature class</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>inputFeatureclass<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ADDRESS'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'DISTANCE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'UNIQUEID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTYLIST'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>geometries<SPAN class="punctuation token">,</SPAN> searchAddress<SPAN class="punctuation token">,</SPAN> searchDistance<SPAN class="punctuation token">,</SPAN> searchid<SPAN class="punctuation token">,</SPAN> txt_list<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Delete cursor object</SPAN>
<SPAN class="keyword token">del</SPAN> cursor<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
