<!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>TOC</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0px; font-family: helvetica, arial, sans-serif; font-size: 90%; } #leftPane { width: 280px; overflow: auto; } /* this line hide layers when out of scale for the inline TOC */ #scaleDiv .agsTOCOutOfScale { display: none; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true, packages: [{ "name": "agsjs", "location": location.pathname.replace(/\/[^/]+$/, "") + '/agsjs' //"location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.05/xbuild/agsjs' // for xdomain load }] }; </script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script type="text/javascript"> var map; var identifyTask, identifyParams; var urlSEFCRI = "http://egisws02.nos.noaa.gov/ArcGIS/rest/services/biogeo/SEFCRI/MapServer"; var layerDynamic; var oldLayerName; var clickGraphicLayer; var visibleLayers; var initialExtent; require([ "dojo/_base/connect", "dojo/_base/array", "dojo/parser", "dojo/ready", "dojo/Deferred", "dojo/dom", "dojo/domReady", "dijit/layout/ContentPane", "dijit/layout/TabContainer", "dijit/registry", "dijit/Dialog", "esri/map", "esri/InfoTemplate", "esri/dijit/Basemap", "esri/dijit/BasemapGallery", "esri/dijit/BasemapLayer", "esri/dijit/InfoWindow", "agsjs/dijit/TOC", "esri/arcgis/utils", "dijit/Menu", "dijit/form/DropDownButton", "dijit/layout/BorderContainer", "dojo/domReady!" ], function ( connect, array, parser, ready, Deferred, dom, domReady, ContentPane, TabContainer, registry, Dialog, Map, InfoTemplate, Basemap, BasemapGallery, BasemapLayer, InfoWindow) { ready(function () { //parser.parse(); }); map = new Map("map", { basemap: "oceans", showAttribution: false, logo: false, center: [-80.2, 26.67], zoom: 11 }); map.resize(); layerDynamic = new esri.layers.ArcGISDynamicMapServiceLayer(urlSEFCRI, { id: 'Dynamic' }); map.addLayers([layerDynamic]); layerDynamic.setVisibleLayers([0]); map.on("layers-add-result", function (event) { console.log("layers-add-result"); try { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: layerDynamic, title: "Legend", slider: true }] }, 'tocDiv'); toc.startup(); } catch (e) { console.log(e.message); } mapReady(map); }); layerDynamic.on("load", function () { var deferred = new Deferred(); deferred = map.setExtent(layerDynamic.initialExtent, true); deferred.then(function () { console.log("Extent set"); initialExtent = map.extent; }); }); var resizeTimer; map.on("load", function (theMap) { connect.connect(dijit.byId('map'), 'resize', function () { //resize the map if the div is resized clearTimeout(resizeTimer); resizeTimer = setTimeout(function () { map.resize(); map.reposition(); }, 500); }); }); function mapReady(map) { console.log("MapReady"); map.on("click", executeIdentifyTask); identifyTask = new esri.tasks.IdentifyTask(urlSEFCRI); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; //identifyParams.layerIds = [0, 117]; identifyParams.layerIds = layerDynamic.visibleLayers; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; map.infoWindow.resize(415, 200); map.infoWindow.setTitle("Results"); } function executeIdentifyTask(evt) { map.graphics.clear(); identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.layerIds = layerDynamic.visibleLayers; oldLayerName = ""; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { return dojo.map(response, function (result) { var feature = result.feature; var infoTemplate = new esri.InfoTemplate("test", "${*}"); var contentString = ""; var sp = new Array(); var sp = feature.attributes; contentString += "<b>" + result.layerName + "</b><hr width = '90%'>"; for (x in sp) { if (x != "OBJECTID" && x != "Shape") { contentString += "<i>" + x + "</i>: " + feature.attributes + "<br/>"; } } var infoTemplate = new esri.InfoTemplate(); infoTemplate.setTitle("Results"); infoTemplate.setContent(contentString); var data = { identifier: "OBJECTID", label: "ID", items: sp }; feature.setInfoTemplate(infoTemplate); return feature; }); }); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); } }); </script> </head> <body class="claro"> <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;"> <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left" splitter="true"> <div id="tocDiv"> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center"> </div> </div> </body> </html>
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer") map.addLayer(basemap); var lubbock = new esri.layers.ArcGISDynamicMapServiceLayer("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer", { id: 'lubbock', opacity: 0.8 }); map.addLayers([lubbock]); dojo.connect(map, 'onLayersAddResult', function (results) { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: lubbock, title: "Lubbock CCTV Assets" }, ] }, 'tocDiv'); toc.startup(); lubbock.setVisibleLayers([9]); }); function mapReady(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer/"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask(evt) { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return dojo.map(response, function (result) { var feature = result.feature; feature.attributes.layerName = result.layerName; if (result.layerName === 'Survey Points') { console.log(feature.attributes.OBJECTID); var template = new esri.InfoTemplate("Survey Points", "<br/> Unique ID: ${UNIQUE_ID}<br/> X Coord: ${X_COORD}<br/> Y Coord: ${Y_COORD}<br/> Z Coord: ${Z_COORD}<br/> Type:${Type}<br/> Status: ${Status}<br/> Data Source: ${DATA_SOURCE}<br/> Shape: ${SHAPE}<br/> Survey Date: ${SURVEY_DATE}<br/>Alternate Name: ${ALT_NAME}"); feature.setInfoTemplate(template); } else if (result.layerName === 'CCTV Observations') { var template = new esri.InfoTemplate("CCTV Observations", "<br/> CCTV Route: ${CCTV_ROUTE}<br/> CCTV Distance: ${CCTV_DISTANCE}<br/> CCTV Code: ${CCTV_CODE}<br/> CCTV Value Percent: ${CCTV_VALUE_PERCENT}<br/> CCTV Clock From: ${CCTV_CLOCK_FROM}<br/> CCTV Clock To: ${CCTV_CLOCK_TO}<br/> CCTV Grade: ${CCTV_GRADE} <br/>CCTV Continuous: ${CCTV_CONTINUOUS}<br/> CCTV Observation Type:${CCTV_OBS_TYPE}<br/> CCTV Observation:${CCTV_OBSERVATION}<br/> CCTV Remark:${CCTV_REMARK} <br/>Shape:${SHAPE}<br/> CCTV Attachment:${CCTV_Attach}"); feature.setInfoTemplate(template); } else if (result.layerName === 'Manholes') { var template = new esri.InfoTemplate("Manholes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Inlets') { var template = new esri.InfoTemplate("Inlets", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Infalls') { var template = new esri.InfoTemplate("Infalls", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Outfalls') { var template = new esri.InfoTemplate("Outfalls", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Channel Features') { var template = new esri.InfoTemplate("Channel Features", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Pipe Features') { var template = new esri.InfoTemplate("Pipe Features", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Playa Centroids') { var template = new esri.InfoTemplate("Playa Centroids", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Pipes') { var template = new esri.InfoTemplate("Pipes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Flumes') { var template = new esri.InfoTemplate("Flumes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Dams') { var template = new esri.InfoTemplate("Dams", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Channels') { var template = new esri.InfoTemplate("Channels", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'CCTV Routes') { var template = new esri.InfoTemplate("CCTV Routes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Virtual Links') { var template = new esri.InfoTemplate("Virtual Links", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Stormwater Systems') { var template = new esri.InfoTemplate("Stormwater Systems", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Asset Footprints') { var template = new esri.InfoTemplate("Asset Footprints", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Playa Lakes') { var template = new esri.InfoTemplate("Playa Lakes", "${*}") feature.setInfoTemplate(template); } map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); return feature; }); }); }
function mapReady(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer/"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17]; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; }
identifyTask = new esri.tasks.IdentifyTask(yourUrl); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParams.width = map.width; identifyParams.height = map.height;
