In City Engine, is there a way to make a flat polygon (foootprint) transparant so that a orthophoto will be seen throu the polygon, in the same way you can in ArcMap (2d)?
If it´s possible can you show me the code?
Best regarde Tomas
attr opacityVal = 0.5
set(material.opacity, opacityVal)
Don't forget this only affects the procedural geometry not the original shapes so you may need to toggle-off the original shapes.
Tanks a lot, I didn't know that I had to toggle-off!
/Tomas
I forgot to mention that it was in City Engine.
As Darren Wiens already indicates there is some information lacking to be able to provide a helpful answer.
Your thread is not posted in a place that is directed towards a specific audience (see: What are Places? ). Please move the content to a relevant place.
If you want to see code samples, it would be good to specify the API or SDK you are using. To see what flavors are available, please visit: ArcGIS for Developers
If you're not talking about ArcMap, what software are you using? ArcScene, AGOL, web map, other?
