My underlying data consists of Latitude and Longitude points, which I have displayed correctly by converting to XY data using GCS_WGS_1984 as the coordinate system. However, whenever I try to convert that XY data using the Kernel Density tool, I always get ERROR 010092: Invalid output extent.
Do you have any resources for projecting Lat/Long into another coordinate system? As I said, I'm a total novice at this, and I'm not entirely sure where to begin.
Greetings All,I can't say that I am having the same luck.Starting with the GCS_WGS_1984 is what my X, Y coordinates are in.
I think you may have misunderstood my question. I have no problem displaying the data in X, Y coordinates on the map. I just have no clue how to get these points to work with Density Kernel. I was told it was because they were in geo coordinates and they needed to be in projections.
This suggestion fixed the issues I was having with the tool. My input point field had A LOT of fields. I removed all but the value that was used as the Z input and it worked.
The issue I was having is the tool would run for part of the spline distance and stop. It was not a cell x cell count issue.
Thanks!
"spline tool extent not complete"
