I’m wondering if someone might see what I’m doing wrong. I have created a blank point feature class with attributes and have published this map service to ArcGIS Online. It works well. I can edit this layer in ArcGIS Online, and I can add points to the same layer using Collector. So far so good.
However, I have now created another blank feature class with a more detailed attribute table. I have followed the exact same steps as with the previous published feature class (so I believe). I have ensured that editing is turned on, added it to a Group in AGOL, but for the life of me I cannot figure out why I cannot edit this layer in AGOL. It simply won’t let me add a point.
To make matters even more confusing, I can see and add the map in Collector, but when I try to add a point I get an error message: “Update Failed. Updates could not be sent”. So I sign out of Collector and revisit ArcGIS Online…and the point I collected using Collector is there in spite of the error message. And I can then delete this point in AGOL….but it still won’t let me add a point in AGOL (we need both capabilities).
Has anyone heard of this type of error before? This is most frustrating.
