If you switch to using a featurelayer, remember to change the URL to use a layer within the service. For instance add /0 to the URL to select the feature layer to display.
Dominque, it seems to be the FeatureLayer that's not showing up -- it's working just fine when I set it as a ArcGISDynamicmapServiceLayer in the XAML, but when I try it as a "FeatureLayer" with the selection mode shown in the sample I don't even see the layer rendering on load. Perhaps it's the way I have the service configured? It's an MSD source obviously. Any idea what I could be doing wrong?
From an ArcGISDynamicmapServiceLayer, you can use either 'Identify' which returns the features of the map service near a point (example : http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/samples/start.htm#Identify ) or a Query task which returns the features of a layer (example : http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/samples/start.htm#SpatialQuery).If you are using the version 2.0 of the API, you can also consider using a featureLayer in SelectionOnly mode (Example : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerSelection).Hope this help./Dominique
