Hi ,
Is there a way that while creating the div , the user can provide name to the div as well as delete.
Similar to Edit bookmarks | ArcGIS API for JavaScript 3.22 .
Aditya
Aditya,
If you keep this up you are going to have me recreate the whole widget in 4.x...
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Bookmarks <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.5</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.5%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.5/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.5%2F" target="_blank">https://js.arcgis.com/4.5/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>bookmark<SPAN class="operator token">-</SPAN>container <SPAN class="punctuation token">{</SPAN> position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN> top<SPAN class="punctuation token">:</SPAN> 100px<SPAN class="punctuation token">;</SPAN> left<SPAN class="punctuation token">:</SPAN> 15px<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 1rem<SPAN class="punctuation token">;</SPAN> background<SPAN class="punctuation token">:</SPAN> #ffffff<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 4px<SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> 1px solid #eeeeee<SPAN class="punctuation token">;</SPAN> box<SPAN class="operator token">-</SPAN>sizing<SPAN class="punctuation token">:</SPAN> border<SPAN class="operator token">-</SPAN>box<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarks <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> position<SPAN class="punctuation token">:</SPAN> relative<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkTable <SPAN class="punctuation token">{</SPAN> border<SPAN class="operator token">-</SPAN>spacing<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>collapse<SPAN class="punctuation token">:</SPAN> collapse<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkItem <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> 5px 10px<SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> 1px solid transparent<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> 36px<SPAN class="punctuation token">;</SPAN> cursor<SPAN class="punctuation token">:</SPAN> pointer<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkItem<SPAN class="operator token">></SPAN><SPAN class="operator token">*</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/*pointer-events: none;*/</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkLabel <SPAN class="punctuation token">{</SPAN> pointer<SPAN class="operator token">-</SPAN>events<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> position<SPAN class="punctuation token">:</SPAN> relative<SPAN class="punctuation token">;</SPAN> float<SPAN class="punctuation token">:</SPAN> left<SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> 26px<SPAN class="punctuation token">;</SPAN> white<SPAN class="operator token">-</SPAN>space<SPAN class="punctuation token">:</SPAN> nowrap<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>overflow<SPAN class="punctuation token">:</SPAN> ellipsis<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> left<SPAN class="punctuation token">;</SPAN> vertical<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> middle<SPAN class="punctuation token">;</SPAN> margin<SPAN class="operator token">-</SPAN>left<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> user<SPAN class="operator token">-</SPAN>select<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkHighlight <SPAN class="punctuation token">{</SPAN> background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> #e2f1fb<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token">*</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">*</SPAN><SPAN class="punctuation token">:</SPAN>before<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">*</SPAN><SPAN class="punctuation token">:</SPAN>after <SPAN class="punctuation token">{</SPAN> <SPAN class="operator token">-</SPAN>moz<SPAN class="operator token">-</SPAN>box<SPAN class="operator token">-</SPAN>sizing<SPAN class="punctuation token">:</SPAN> border<SPAN class="operator token">-</SPAN>box<SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>box<SPAN class="operator token">-</SPAN>sizing<SPAN class="punctuation token">:</SPAN> border<SPAN class="operator token">-</SPAN>box<SPAN class="punctuation token">;</SPAN> box<SPAN class="operator token">-</SPAN>sizing<SPAN class="punctuation token">:</SPAN> border<SPAN class="operator token">-</SPAN>box<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriAddBookmark <SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> #6e6e6e<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkEditBox <SPAN class="punctuation token">{</SPAN> position<SPAN class="punctuation token">:</SPAN> fixed<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 14px<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> 34px<SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> 200px<SPAN class="punctuation token">;</SPAN> z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">999</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> 10px<SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>bottom<SPAN class="punctuation token">:</SPAN> 1px solid #007ac2<SPAN class="punctuation token">;</SPAN> background<SPAN class="punctuation token">:</SPAN> #fff <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkEditBox<SPAN class="punctuation token">:</SPAN>focus <SPAN class="punctuation token">{</SPAN> outline<SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkRemoveImage<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkEditImage <SPAN class="punctuation token">{</SPAN> float<SPAN class="punctuation token">:</SPAN> right<SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> 30px<SPAN class="punctuation token">;</SPAN> cursor<SPAN class="punctuation token">:</SPAN> pointer<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"CalciteWebCoreIcons"</SPAN><SPAN class="punctuation token">;</SPAN> speak<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 16px<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>style<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>weight<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>variant<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>transform<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>indent<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>font<SPAN class="operator token">-</SPAN>smoothing<SPAN class="punctuation token">:</SPAN> antialiased<SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>moz<SPAN class="operator token">-</SPAN>osx<SPAN class="operator token">-</SPAN>font<SPAN class="operator token">-</SPAN>smoothing<SPAN class="punctuation token">:</SPAN> grayscale<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> 26px<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> center<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkItem<SPAN class="punctuation token">:</SPAN>before <SPAN class="punctuation token">{</SPAN> float<SPAN class="punctuation token">:</SPAN> left<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"CalciteWebCoreIcons"</SPAN><SPAN class="punctuation token">;</SPAN> speak<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 16px<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>style<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>weight<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>variant<SPAN class="punctuation token">:</SPAN> normal<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>transform<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>indent<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>font<SPAN class="operator token">-</SPAN>smoothing<SPAN class="punctuation token">:</SPAN> antialiased<SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>moz<SPAN class="operator token">-</SPAN>osx<SPAN class="operator token">-</SPAN>font<SPAN class="operator token">-</SPAN>smoothing<SPAN class="punctuation token">:</SPAN> grayscale<SPAN class="punctuation token">;</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN> inherit<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> 26px<SPAN class="punctuation token">;</SPAN> margin<SPAN class="operator token">-</SPAN>right<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkRemoveImage<SPAN class="punctuation token">:</SPAN>before <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"\e600"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkEditImage<SPAN class="punctuation token">:</SPAN>before <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"\e61b"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriAddBookmark<SPAN class="punctuation token">:</SPAN>before <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"\e620"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esriBookmarkItem<SPAN class="punctuation token">:</SPAN>after <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN> display<SPAN class="punctuation token">:</SPAN> table<SPAN class="punctuation token">;</SPAN> clear<SPAN class="punctuation token">:</SPAN> both<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> extents <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-class"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-construct"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-geometry"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/keys"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/json"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/lang"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> domClass<SPAN class="punctuation token">,</SPAN> dojoQuery<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> domConstruct<SPAN class="punctuation token">,</SPAN> domGeom<SPAN class="punctuation token">,</SPAN> keys<SPAN class="punctuation token">,</SPAN> JSON<SPAN class="punctuation token">,</SPAN> lang <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">119.4179</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">36.7783</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Bookmark data objects</SPAN> <SPAN class="keyword token">var</SPAN> bookmarkJSON <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> first<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"extent"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"xmin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">12975151.579395358</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3993919.9969406975</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"xmax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">12964144.647322308</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4019507.292159126</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Palm Springs, CA"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> second<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"extent"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"xmin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13052123.666878553</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4024962.9850527253</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"xmax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13041116.734805504</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4050550.280271154</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Redlands, California"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> third<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"extent"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"xmin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13048836.874662295</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3844839.127898948</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"xmax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13037829.942589246</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ymax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3870426.4231173764</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"San Diego, CA"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">initBookmarksWidget</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> bmDiv <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"bookmarksDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>bmDiv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bookmark-container"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bookmarksdiv <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriBookmarks"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> bmDiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmlistdiv <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriBookmarkList"</SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'250px'</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> bookmarksdiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriBookmarkTable"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> bmlistdiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmadditemdiv <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriBookmarkItem esriAddBookmark"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> bookmarksdiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> addbmlabeldiv <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriBookmarkLabel"</SPAN><SPAN class="punctuation token">,</SPAN> innerHTML<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Add Bookmark"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>bmadditemdiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>bmadditemdiv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> bookmarkEvent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>bmadditemdiv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseover"</SPAN><SPAN class="punctuation token">,</SPAN> addMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>bmadditemdiv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseout"</SPAN><SPAN class="punctuation token">,</SPAN> removeMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//process the bookmarkJSON</SPAN> Object<SPAN class="punctuation token">.</SPAN><SPAN class="token function">keys</SPAN><SPAN class="punctuation token">(</SPAN>bookmarkJSON<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>bookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> bmName <SPAN class="operator token">=</SPAN> bookmarkJSON<SPAN class="punctuation token">[</SPAN>bookmark<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">||</SPAN> <SPAN class="string token">"Bookmark "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>index <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> theExtent <SPAN class="operator token">=</SPAN> Extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fromJSON</SPAN><SPAN class="punctuation token">(</SPAN>bookmarkJSON<SPAN class="punctuation token">[</SPAN>bookmark<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> item <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<div class="esriBookmarkItem" data-fromuser="false" data-extent="'</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>xmin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>ymin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>xmax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>ymax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">.</SPAN>wkid <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"><div class="esriBookmarkLabel">'</SPAN> <SPAN class="operator token">+</SPAN> bmName <SPAN class="operator token">+</SPAN> <SPAN class="string token">'</div><div title="Remove" class="esriBookmarkRemoveImage"></div><div title="Edit" class="esriBookmarkEditImage"></div></div>'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"last"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkRemoveImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> removeBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkEditImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> editBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> bookmarkEvent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseover"</SPAN><SPAN class="punctuation token">,</SPAN> addMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseout"</SPAN><SPAN class="punctuation token">,</SPAN> removeMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> bookmarkJSON<SPAN class="punctuation token">[</SPAN>bookmark<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//process the local storage bookmarks</SPAN> <SPAN class="token function">readBookmarks</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token function">initBookmarksWidget</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">addMouseOverClass</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>currentTarget<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esriBookmarkHighlight"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">removeMouseOverClass</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>currentTarget<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esriBookmarkHighlight"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">removeBookmark</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmItem <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN>parentNode<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmEditItem <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkEditBox"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>bmEditItem<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroy</SPAN><SPAN class="punctuation token">(</SPAN>bmEditItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroy</SPAN><SPAN class="punctuation token">(</SPAN>bmItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>writeCurrentBookmarks<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">writeCurrentBookmarks</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> extents <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bookMarkItems <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkItem"</SPAN><SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> bookMarkItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">.</SPAN>dataset<SPAN class="punctuation token">.</SPAN>fromuser<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> extArr <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>dataset<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">","</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> theExt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> xmin<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> ymin<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> xmax<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> ymax<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">parseInt</SPAN><SPAN class="punctuation token">(</SPAN>extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> sExt <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> extent<SPAN class="punctuation token">:</SPAN> theExt<SPAN class="punctuation token">,</SPAN> name<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkLabel"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="punctuation token">}</SPAN> extents<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>sExt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> stringifedExtents <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>extents<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> localStorage<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"myBookmarks"</SPAN><SPAN class="punctuation token">,</SPAN> stringifedExtents<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">editBookmark</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmItem <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN>parentNode<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmItemName <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkLabel"</SPAN><SPAN class="punctuation token">,</SPAN> bmItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> output <SPAN class="operator token">=</SPAN> domGeom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">position</SPAN><SPAN class="punctuation token">(</SPAN>bmItem<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> editItem <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<input class="esriBookmarkEditBox" style="top: '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">.</SPAN>y <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px; left: '</SPAN> <SPAN class="operator token">+</SPAN> output<SPAN class="punctuation token">.</SPAN>x <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px;">'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> editItem<SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> bmItemName<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"keypress"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> charOrCode <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>charCode <SPAN class="operator token">||</SPAN> evt<SPAN class="punctuation token">.</SPAN>keyCode <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>charOrCode <SPAN class="operator token">===</SPAN> keys<SPAN class="punctuation token">.</SPAN>ENTER<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkLabel"</SPAN><SPAN class="punctuation token">,</SPAN> bmItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> editItem<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroy</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">writeCurrentBookmarks</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> editItem<SPAN class="punctuation token">.</SPAN><SPAN class="token function">focus</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">bookmarkEvent</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">contains</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esriAddBookmark"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> item <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<div class="esriBookmarkItem" data-fromuser="true" data-extent="'</SPAN> <SPAN class="operator token">+</SPAN> view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">.</SPAN>wkid <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"><div class="esriBookmarkLabel">New Bookmark</div><div title="Remove" class="esriBookmarkRemoveImage"></div><div title="Edit" class="esriBookmarkEditImage"></div></div>'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"last"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> output <SPAN class="operator token">=</SPAN> domGeom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">position</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> editItem <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<input class="esriBookmarkEditBox" style="top: '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">.</SPAN>y <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px; left: '</SPAN> <SPAN class="operator token">+</SPAN> output<SPAN class="punctuation token">.</SPAN>x <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px;">'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"keypress"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> charOrCode <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>charCode <SPAN class="operator token">||</SPAN> evt<SPAN class="punctuation token">.</SPAN>keyCode <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>charOrCode <SPAN class="operator token">===</SPAN> keys<SPAN class="punctuation token">.</SPAN>ENTER<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkLabel"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> editItem<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroy</SPAN><SPAN class="punctuation token">(</SPAN>editItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> sExt <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> name<SPAN class="punctuation token">:</SPAN> editItem<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">,</SPAN> extent<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">.</SPAN>extent <SPAN class="punctuation token">}</SPAN> extents<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>sExt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> stringifedExtents <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>extents<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> localStorage<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"myBookmarks"</SPAN><SPAN class="punctuation token">,</SPAN> stringifedExtents<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkRemoveImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> removeBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkEditImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> editBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> bookmarkEvent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseover"</SPAN><SPAN class="punctuation token">,</SPAN> addMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseout"</SPAN><SPAN class="punctuation token">,</SPAN> removeMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> editItem<SPAN class="punctuation token">.</SPAN><SPAN class="token function">focus</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> extArr <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN>dataset<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">","</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> xmin<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> ymin<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> xmax<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> ymax<SPAN class="punctuation token">:</SPAN> extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">parseInt</SPAN><SPAN class="punctuation token">(</SPAN>extArr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> duration<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">readBookmarks</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>localStorage<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"myBookmarks"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> extentArray <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN>localStorage<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"myBookmarks"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>extentArray<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> extentArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>extentJSON<SPAN class="punctuation token">,</SPAN> index<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> bmName <SPAN class="operator token">=</SPAN> extentJSON<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">||</SPAN> <SPAN class="string token">"Bookmark "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>index <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> theExtent <SPAN class="operator token">=</SPAN> Extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fromJSON</SPAN><SPAN class="punctuation token">(</SPAN>extentJSON<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> extents<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>extentJSON<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> bmTable <SPAN class="operator token">=</SPAN> <SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> item <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<div class="esriBookmarkItem" data-fromuser="true" data-extent="'</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>xmin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>ymin <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>xmax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>ymax <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN> <SPAN class="operator token">+</SPAN> theExtent<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">.</SPAN>wkid <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"><div class="esriBookmarkLabel">'</SPAN> <SPAN class="operator token">+</SPAN> bmName <SPAN class="operator token">+</SPAN> <SPAN class="string token">'</div><div title="Remove" class="esriBookmarkRemoveImage"></div><div title="Edit" class="esriBookmarkEditImage"></div></div>'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> bmTable<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"last"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkRemoveImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> removeBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">dojoQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".esriBookmarkEditImage"</SPAN><SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> editBookmark<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> bookmarkEvent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseover"</SPAN><SPAN class="punctuation token">,</SPAN> addMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"mouseout"</SPAN><SPAN class="punctuation token">,</SPAN> removeMouseOverClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">e</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">warn</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Could not parse bookmark JSON"</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">.</SPAN>message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"calcite"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"bookmarksDiv"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
