Nick,Are you getting the same error message as the first post? How did you migrate/load your parcel fabric to SDE? Was there a topology invloved? If so, is there a chance that it was validated on the default after you created the version below? That may cause a lock on all of the parcels. Since your testing, you may try dropping the verison and then recreating it from a "clean" default version.
David - try commiting the job that was edited to release the locks - The job needs to be committed even on default. The Commit Job command needs to be added from the Customize menu.And yes, we need to get that command back on the job context menu, it should not be hidden in Customize.Christine
Help - how do I get rid of this error. I'm editing in default so there IS nothing to reconcile. We also run a script that does a compress every night... is this a bug? Does the error refer to orphaned locks? How can I get the error to go away?Please see screen shot for full text of error.Thanks
