hello
I'm trying to export a map with embedded pictures.
i tried to insert the pictures with the "insert" tool but the quality of them drops.
can anyone help me?
that happenes on JPG and PDF exports.
thanks,
Maya
There are pros and cons for each format as indicated in this help topic Perhaps try *.png or check the guidance in the help topic for specific formats.
Hello Dan,
Thanks for your respond…
I now see that the file do export, but only in a relatively low resolution (100 dpi)
I usually work with 300 dpi.
Do you know how to solve this maybe?
Read the link in detail regarding image formats, for example
JPEG files are compressed image files. They support 24-bit color and have been a popular choice for use on the web because JPEG file size is often substantially smaller than many other image formats. However, the JPEG compression algorithm is lossy and is not recommended for most map images, as line drawings and text or iconic graphics become blurred by compression artifacts. Thus, PNG is usually a superior format for map images. JPEGs exported from the data view in ArcMap can be generated with an accompanying world file for use as georeferenced raster data.
I understand,
But the same problem happened with the PNG file, in the wanted resolution…
