I am currently using Xcode 7 (Beta 6). I can build and run against the Simulator. But when I attempt to build and run against a real iPhone 6 running iOS 9, I get the following link error:
ld: 'Pods/ArcGIS-Runtime-SDK-iOS/ArcGIS.framework/ArcGIS(libArcGISRT.a-arm64-master.o)' does not contain bitcode. You must rebuild it with bitcode enabled (Xcode setting ENABLE_BITCODE), obtain an updated library from the vendor, or disable bitcode for this target. for architecture arm64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Any ideas?
