var bytes:ByteArray=lfileRef.data; this.loadedObj=bytes.readObject(); map.scale=loadedObj.scale; map.extent=loadedObj.extent; var layerIDsArr:Array = map.layerIds; for(var i:Number = 0; i < layerIDsArr.length; i++) { var tmpLayer:Layer = map.getLayer(layerIDsArr); for(var j:Number=0;j<loadedObj.objs.length;j++) { if(tmpLayer.id==loadedObj.objs.mainLayer.toString()){ tmpLayer.visible=true; this.hideLayerItem=new Array(); if(tmpLayer is ArcGISDynamicMapServiceLayer){ var dmsl:ArcGISDynamicMapServiceLayer=tmpLayer as ArcGISDynamicMapServiceLayer; this.loadedLayer=null; // Remove all checks and also remove any visible sublayers for each(var lyrInfo:LayerInfo in dmsl.layerInfos){ this.hideLayer(dmsl,lyrInfo); } // handle the group layers and call the handler to AppEvent.addListener(AppEvent.VISIBLE_LAYERS_RETURNED,handleVisibleLayers); this.loadedLayer=dmsl; for each(var k:int in loadedObj.objs.visibleLayer){ var disObj:Object=new Object(); disObj.index=k; disObj.visibility=true; disObj.mainLayer=dmsl.name; AppEvent.dispatch(AppEvent.LAYER_VISIBILITY_CHANGED,disObj); } // Code below to make the child of group invisible but maintaining the tick of the group var newVisLayer:ArrayCollection=new ArrayCollection(this.loadedObj.objs.visibleLayer); for (var x:int=0; x<newVisLayer.length;x++){ for(var y:int=0;y<this.hideLayerItem.length;y++){ if(newVisLayer==this.hideLayerItem){ var idx:int=newVisLayer.getItemIndex(this.hideLayerItem); newVisLayer.removeItemAt(idx); } } } this.loadedLayer.visibleLayers=newVisLayer; } } } // end of inner for }
//////////////////////////////////////////////////////////////////////////////// // // Copyright � 2008 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/FlexViewer/License.txt // //////////////////////////////////////////////////////////////////////////////// package com.esri.viewer.components.toc.tocClasses { import com.esri.ags.events.ExtentEvent; import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import com.esri.ags.layers.Layer; import com.esri.ags.layers.supportClasses.LayerInfo; import com.esri.viewer.ViewerContainer; /** * A TOC item representing a member layer of an ArcGIS or ArcIMS map service. * This includes group layers that contain other member layers. */ public class TocLayerInfoItem extends TocItem { public function TocLayerInfoItem( parentItem:TocItem, layerInfo:LayerInfo,tLayer:Layer) { super(parentItem); // Added line below _rootInfo=tLayer as ArcGISDynamicMapServiceLayer; _layerInfo = layerInfo; label = layerInfo.name; // Set the initial visibility without causing a layer refresh setVisible(layerInfo.defaultVisibility, false); ViewerContainer.getInstance().mapManager.map.addEventListener(ExtentEvent.EXTENT_CHANGE,checkExtent); } internal static const DEFAULT_MAX:Number = 0; private var _maxScale:Number = DEFAULT_MAX; public function set maxScale( value:Number ):void { _maxScale = value; this.scaledependant = true; if (_maxScale > 0 ){ if ((ViewerContainer.getInstance().mapManager.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((ViewerContainer.getInstance().mapManager.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } public function get maxScale():Number { return _maxScale; } private function checkExtent(evt:ExtentEvent):void{ this.scaledependant = true; if (_maxScale > 0 ){ if ((ViewerContainer.getInstance().mapManager.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((ViewerContainer.getInstance().mapManager.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } internal static const DEFAULT_MIN:Number = 0; private var _minScale:Number = DEFAULT_MIN; public function set minScale( value:Number ):void { _minScale = value; this.scaledependant = true; if (_maxScale > 0 ){ if ((ViewerContainer.getInstance().mapManager.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((ViewerContainer.getInstance().mapManager.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } public function get minScale():Number { return _minScale; } //-------------------------------------------------------------------------- // Property: layerInfo //-------------------------------------------------------------------------- private var _layerInfo:LayerInfo; /** * The map layer info that backs this TOC item. */ public function get layerInfo():LayerInfo { return _layerInfo; } ///-------------------------------------------------------------------------- // Property: _rootNode ///-------------------------------------------------------------------------- private var _rootInfo:ArcGISDynamicMapServiceLayer; /** * The map layer root behind this TOC item. */ public function get rootInfo():ArcGISDynamicMapServiceLayer { return _rootInfo; } //-------------------------------------------------------------------------- // // Methods // //-------------------------------------------------------------------------- /** * @private */ override internal function setVisible( value:Boolean, layerRefresh:Boolean = true ):void { // Set the visible state of all children, but defer the layer refresh for each (var item:TocItem in children) { //if(super.preventPropogation==false){ item.setVisible(value, false); //} } // Set the visible state of this item, but defer the layer refresh super.setVisible(value, false); // Allow the layer refresh now that all changes have been made if (layerRefresh) { refreshLayer(); } } } }
i modified the code as below to make it work but i had to do alot of other custom code in my widget, but this might give you some idea. public function TocItem( parentItem:TocItem = null ) { _parent = parentItem; AppEvent.addListener(AppEvent.LAYER_VISIBILITY_CHANGED,updateCB); } private function updateCB(event:AppEvent):void { var disObj:Object=event.data; //if(disObj.mainLayer!=null){ if(this is TocLayerInfoItem) { var tli:TocLayerInfoItem = this as TocLayerInfoItem; if(tli.rootInfo.name==disObj.mainLayer || disObj.mainLayer==null){ //var tmpLayer:ArcGISDynamicMapServiceLayer=disObj.mainLayer; if(tli.layerInfo.id == disObj.index){ //this.preventPropogation=true; if(disObj.visibility==false){ this.setVisibleDirect(false); //this.visible=false; } if(disObj.visibility==true){ this.setVisibleDirect(true); //this.visible=true; } if(tli.isGroupLayer()){ AppEvent.dispatch(AppEvent.VISIBLE_LAYERS_RETURNED,tli.layerInfo.id); } } }// end of mainlayer if } //} }
I would like to change the TOC as follows:1. Turn on a sub layer automatically from a separate widget2. Switch off all sub layers when group layer is switched off3. Switch on group layer automatically when a sub layer is turn on4. Disable / Enable a TOC node from a separate widgetIs this feasible in the Flex Viewer?
var visLayers:ArrayCollection = dmsl.visibleLayers; var newVisLayer:ArrayCollection=new ArrayCollection(obj.visLyrs.visibleLayer); for each(var j:int in newVisLayer){ AppEvent.dispatch(AppEvent.LAYER_VISIBILITY_CHANGED,j); }
public function TocItem( parentItem:TocItem = null ) { _parent = parentItem; //ViewerContainer.addEventListener(AppEvent.LAYER_VISIBILITY_CHANGED, updateCB); AppEvent.addListener(AppEvent.LAYER_VISIBILITY_CHANGED,updateCB); } private function updateCB(event:AppEvent):void { if(this is TocLayerInfoItem) { var tli:TocLayerInfoItem = this as TocLayerInfoItem; if(tli.layerInfo.id == event.data){ setVisibleDirect(_visible ? false : true); } }
