I see that JS API 4.2 doesn't yet support urlUtils.
Is this awaiting or is there a new/better solution?
Does anyone have an example to build a simple app with JS 4.2 that will accept url parameters like the 3.19 exp_history example?
https://developers.arcgis.com/javascript/3/samples/exp_history/?parceled=1919402007
PW
Are you looking for urlUtils.urlToObject()?
urlUtils | API Reference | ArcGIS API for JavaScript 4.2
urlUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">urlToObject</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fdevelopers.arcgis.com%2Fjavascript%2F3%2Fsamples%2Fexp_history%2F%3Fparceled%3D191940200" target="_blank">https://developers.arcgis.com/javascript/3/samples/exp_history/?parceled=191940200</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/** outputs { <SPAN> "path": "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fdevelopers.arcgis.com%2Fjavascript%2F3%2Fsamples%2Fexp_history%2F" target="_blank">https://developers.arcgis.com/javascript/3/samples/exp_history/</A><SPAN>",</SPAN> "query": { "parceled": "1919402007" } } **/</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Looks like it moved from esri/urlUtils to esri/core/urlUtils
Thanks Rene!
You could still do this with strictly javascript. I mean, it's certainly more elegant and nice to have a helper like the urlUtils but isn't that hard to do otherwise. Here's a snippit that zooms the map to a lat/long if passed as a parameter in the URL:
<SPAN class="comment token">//If a coordinate location was passed as a parameter, zoom the map to it</SPAN> <SPAN class="comment token">//Evaluate the URL of this HTML page to determine if any parameters were passed with it</SPAN> htmlPagePath <SPAN class="operator token">=</SPAN> window<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> qLocation <SPAN class="operator token">=</SPAN> htmlPagePath<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'?'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>qLocation <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> passedLatLong <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> passedLatLong <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>passedLatLong<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//Extract the lat/long coordinates passed as a parameter with the URL</SPAN> <SPAN class="keyword token">var</SPAN> coordStr <SPAN class="operator token">=</SPAN> window<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">substr</SPAN><SPAN class="punctuation token">(</SPAN>qLocation <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>window<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> coords <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Array</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> coords <SPAN class="operator token">=</SPAN> coordStr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">','</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Create a lat/long point</SPAN> <SPAN class="keyword token">var</SPAN> bridgeLoc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>coords<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>coords<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> theLatLongPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>coords<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>coords<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> webMercatorPoint <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>theLatLongPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">centerAndZoom</SPAN><SPAN class="punctuation token">(</SPAN>webMercatorPoint<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This just assumed that the url was something like "http://server/folder/index.html?-122,48"
You can easily adjust this to be "...?parcelId=xyz"
