1 CREATE OR REPLACE VIEW forum_view10 AS 2 SELECT l.objectid loc_id,r.objectid rec_id,l.point 3 FROM rectangles2 r 4 LEFT OUTER JOIN locations l 5* ON SDE.st_within(l.point,r.poly) = 1 SQL> / View created. % sdelayer -o register -l forum_view10,point -e np -R 3 -C loc_id,USER -t ST_GEOMETRY ArcSDE 10.1 for Oracle11g Build 768 Thu Aug 23 15:57:13 2012 Layer Administration Utility ----------------------------------------------------- Successfully Created Layer. % sdequery -N -t forum_view10 ArcSDE 10.1 Generic Query Tool Tue Feb 26 10:20:40 2013 ------------------------------------------------------------------------ 8000 rows found in 988.24 ms
% cat ident.ctl COORDREF_XY -210,-120,1000000 COORDSYS GCS_WGS_1984 ENVELOPE 0,0,20,20 SKIP 1 REGISTER loc_id(USER) META id1:VERBOSE="TRUE" META id1:SUMMARIZE="true" META id1:TABLE="rectangles2" META id1:COLUMN="poly" META id1:ALIAS="point" META id1:USE_CACHE="true" COLUMNS loc_id Int32 - 10 N rec_id Identity(id1,objectid) - 10 Y point WKTShape - 1 Y END % sdequery -t locations -C objectid,point -d - -q | \ ascinfo -o scan -f - -C ident.ctl ArcSDE 10.1 Dynamic ASCII Table Utility Tue Feb 26 10:39:07 2013 ------------------------------------------------------------------------ ! id1: Cache size limited to 128.00Mb ! id1: Connecting to instance 'localhost:esri_sde' as 'staff'... ! id1: Connection created at Tue Feb 26 10:39:07 2013 ! id1: 20 features cached using 124.8Kb in 85.52 ms 8000 rows found in 271.95 ms ! id1: 8000 features found in 194.05 ms (24 us/query) ! id1: Disconnected at Tue Feb 26 10:39:07 2013 8000 rows read in 237.88 ms
% asc2sde -o create -l rectangles,poly -g 5 -C rect.ctl ASCII to ArcSDE 10.1 Loader Utility Mon Feb 25 14:33:45 2013 ------------------------------------------------------------------------ Results: Records read: 20 Rows created: 20 Insert time: 39.64 ms (504.49 TPS) Elapsed time: 993.10 ms % asc2sde -o create -l locations,point -g 3 -C pnts.ctl ASCII to ArcSDE 10.1 Loader Utility Mon Feb 25 14:34:11 2013 ------------------------------------------------------------------------ Results: Records read: 8000 Rows created: 8000 Insert time: 1.27 secs (6290.73 TPS) Elapsed time: 3.04 secs 1 create view forum_view as 2 select l.objectid loc_id,r.objectid rec_id,r.poly 3 from locations l,rectangles r 4* where SDE.st_intersects(r.poly,l.point) = 1 SQL> / View created. % sdelayer -o register -l forum_view,poly -e na+ -R 3 -C loc_id,USER -t ST_GEOMETRY ArcSDE 10.1 for Oracle11g Build 768 Thu Aug 23 15:57:13 2012 Layer Administration Utility ----------------------------------------------------- Successfully Created Layer. % sdequery -N -t locations ArcSDE 10.1 Generic Query Tool Mon Feb 25 14:35:29 2013 ------------------------------------------------------------------------ 8000 rows found in 220.49 ms % sdequery -N -t rectangles ArcSDE 10.1 Generic Query Tool Mon Feb 25 14:35:36 2013 ------------------------------------------------------------------------ 20 rows found in 10.89 ms % sdequery -N -t forum_view ArcSDE 10.1 Generic Query Tool Mon Feb 25 14:35:48 2013 ------------------------------------------------------------------------ 8000 rows found in 5.47 secs 1 create view forum_view2 as 2 select l.objectid loc_id,r.objectid rec_id,r.poly 3 from locations l,rectangles r 4* where SDE.st_contains(r.poly,l.point) = 1 SQL> / View created. % sdelayer -o register -l forum_view2,poly -e na+ -R 3 -C loc_id,USER -t ST_GEOMETRY ArcSDE 10.1 for Oracle11g Build 768 Thu Aug 23 15:57:13 2012 Layer Administration Utility ----------------------------------------------------- Successfully Created Layer. % sdequery -N -t forum_view2 ArcSDE 10.1 Generic Query Tool Mon Feb 25 15:05:36 2013 ------------------------------------------------------------------------ 8000 rows found in 5.56 secs 1 create view forum_view3 as 2 select l.objectid loc_id,r.objectid rec_id,r.poly 3 from locations l,rectangles r 4* where SDE.st_within(l.point,r.poly) = 1 SQL> / View created. % sdelayer -o register -l forum_view3,poly -e na+ -R 3 -C loc_id,USER -t ST_GEOMETRY ArcSDE 10.1 for Oracle11g Build 768 Thu Aug 23 15:57:13 2012 Layer Administration Utility ----------------------------------------------------- Successfully Created Layer. % sdequery -N -t forum_view3 ArcSDE 10.1 Generic Query Tool Mon Feb 25 15:15:32 2013 ------------------------------------------------------------------------ 8000 rows found in 1.10 secs
