Hello everyone,
i try to remove a layer that located in
\PROJECTS\zfonGivatShmuel\gis\layers\6_9_15\gvul.shp
with this code but i get an error:
import arcpy,os,sys
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
counter = 0
for mxdname in arcpy.ListFiles("*.mxd"):
print mxdname # print list of mxd's in the folder
mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
for lyr in arcpy.mapping.ListLayers(mxd, "", df):
if lyr.dataSource == r"D:\PROJECTS\zfonGivatShmuel\gis\layers\6_9_15\gvul.shp":
arcpy.mapping.RemoveLayer(df, lyr)
print 'remove'
mxd.save()
del mxdthis is the error:
environment.mxd
remove
File "C:\yaron\shonot\software\gis\tools\YARON_SCRIPTS\RemoveLayer by data source.py", line 15, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\_base.py", line 78, in _get
(attr_name, self.__class__.__name__))
NameError: The attribute 'dataSource' is not supported on this instance of Layer.
thanks for any help!!
