<esri:FeatureLayer ID="IncidentsLayer" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/0" MouseLeftButtonUp="FeatureLayer_MouseLeftButtonUp" AutoSave="False" DisableClientCaching="True" OutFields="*" Mode="OnDemand" />
private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs e) { FeatureLayer featureLayer = sender as FeatureLayer; for (int i = 0; i < featureLayer.SelectionCount; i++) featureLayer.SelectedGraphics.ToList().UnSelect(); e.Graphic.Select(); MyAttachmentEditor.GraphicSource = e.Graphic; }
if (e.Action == Editor.EditAction.ClearSelection || e.Action == Editor.EditAction.Select) { MyAttachmentEditor.GraphicSource = null; } else if (e.Action == Editor.EditAction.Add || e.Action == Editor.EditAction.Select) { foreach (var edit in e.Edits) { if (e.Action == Editor.EditAction.Add || edit.Graphic.Selected) { MyAttachmentEditor.GraphicSource = edit.Graphic; break; } } }
<Button x:Name="ViewAttribute" Command="{Binding Select}" CommandParameter="new" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="View Attachments" Click="ViewAttribute_Click"> <Image Source="Images/AttImage.png" Stretch="None"/> </Button>
<esri:FeatureLayer ID="TPOINTS" DisableClientCaching="True" AutoSave="False" Url="http://myserver.com/ArcGIS/rest/services/edittest/FeatureServer/0" OutFields="*" Mode="OnDemand" />
<!-- Editing Tools --> <userControls:CollapsiblePanel x:Name="EditorTool" IsExpanded="True" RenderTransformOrigin="1,0" VerticalContentAlignment="Top" HorizontalContentAlignment="Right" Margin="0,75,10,0" Effect="{StaticResource dropShadow}" > <Grid x:Name="EditorToolStripGrid" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" > <Border Background="{StaticResource CommonPanelBorderBackgroundBrush}" BorderBrush="{StaticResource CommonBorderBrush}" BorderThickness="1" CornerRadius="6" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"> <Border Effect="{StaticResource miniDropShadow}" Style="{StaticResource RibbonElementBorder}" Padding="15" Margin="10" > <StackPanel x:Name="EditorToolStrip" Margin="0,5,5,0" > <Border Background="#00919191" CornerRadius="5" HorizontalAlignment="Right" VerticalAlignment="Top" Padding="5" BorderBrush="Transparent"> <Border.Effect> <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <StackPanel Orientation="Vertical" HorizontalAlignment="Right" Margin="0,5,5,0" VerticalAlignment="Top" > <esri:EditorWidget x:Name="MyEditorWidget" Map="{Binding ElementName=Map}" Width="300" AutoSelect="False" AlwaysDisplayDefaultTemplates="True" GeometryServiceUrl="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" ShowAttributesOnAdd="True" Loaded="EditorWidget_Loaded" Style="{StaticResource EditorWidgetStyle1}" EditCompleted="EditorWidget_EditCompleted"/> </StackPanel> </Border> </StackPanel> </Border> </Border> <Image Source="images/CloseX.png" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="3" Stretch="None" Cursor="Hand" ToolTipService.ToolTip="Close" > <i:Interaction.Triggers> <i:EventTrigger EventName="MouseLeftButtonDown" > <actions:ToggleCollapseAction TargetName="EditorTool" /> </i:EventTrigger> </i:Interaction.Triggers> </Image> </Grid> </userControls:CollapsiblePanel> <!-- END Editing Tools--> <!-- Attachment Tools --> <Grid x:Name="AttachmentGrid" HorizontalAlignment="Right" VerticalAlignment="Center" Margin="0,20,15,0" Visibility="Collapsed"> <Border Background="{StaticResource CommonPanelBorderBackgroundBrush}" BorderBrush="{StaticResource CommonBorderBrush}" BorderThickness="1" CornerRadius="6" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"> <Border Effect="{StaticResource miniDropShadow}" Style="{StaticResource RibbonElementBorder}" Padding="15" Margin="10" > <StackPanel Orientation="Vertical"> <TextBlock Text="Click on a point feature to select it, and click the 'Add' button to attach a file." Width="275" TextAlignment="Left" Margin="20,20,20,5" TextWrapping="Wrap" FontWeight="Bold"/> <esri:AttachmentEditor x:Name="MyAttachmentEditor" VerticalAlignment="Top" Margin="20,5,20,20" Background="WhiteSmoke" Width="280" Height="190" HorizontalAlignment="Right" FeatureLayer="{Binding Layers[TPOINTS], ElementName=Map}" Filter="All Files (*.*)|*.*|Image Files|*.tif;*.jpg;*.gif;*.png;*.bmp|Text Files (.txt)|*.txt" FilterIndex="1" Multiselect="True" UploadFailed="MyAttachmentEditor_UploadFailed"> </esri:AttachmentEditor> </StackPanel> </Border> </Border> <Image Source="images/CloseX.png" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="3" Stretch="None" Cursor="Hand" ToolTipService.ToolTip="Close" > <i:Interaction.Triggers> <i:EventTrigger EventName="MouseLeftButtonDown" > <actions:ToggleCollapseAction TargetName="AttachmentTool" /> </i:EventTrigger> </i:Interaction.Triggers> </Image> </Grid> <!-- END Attachment Tools-->
#region Edit Tools private void EditorWidget_Loaded(object sender, RoutedEventArgs e) { string[] myLayerIDs = { "TPOINTS" }; MyEditorWidget.LayerIDs = myLayerIDs; } #endregion #region Attachment Tool private void MyAttachmentEditor_UploadFailed(object sender, ESRI.ArcGIS.Client.Toolkit.AttachmentEditor.UploadFailedEventArgs e) { MessageBox.Show(e.Result.Message); } private void ViewAttribute_Click(object sender, RoutedEventArgs e) { if (AttachmentGrid.Visibility == Visibility.Visible) { AttachmentGrid.Visibility = Visibility.Collapsed; attachmentEditorActive = false; } else { AttachmentGrid.Visibility = Visibility.Visible; attachmentEditorActive = !attachmentEditorActive; } } //public event EventHandler<Editor.EditEventArgs> EditCompleted //{ //} private void EditorWidget_EditCompleted(object sender, Editor.EditEventArgs e) { if (e.Action == Editor.EditAction.Select && attachmentEditorActive) { foreach (var edit in e.Edits) { MyAttachmentEditor.GraphicSource = edit.Graphic; break; } } } #endregion
Command="{Binding Select}" CommandParameter="new" Click="Button_Click"
bool attachmentEditorActive = false; private void Button_Click(object sender, RoutedEventArgs e) { attachmentEditorActive = !attachmentEditorActive; } private void EditorWidget_EditCompleted(object sender, Editor.EditEventArgs e) { if (e.Action == Editor.EditAction.Select && attachmentEditorActive) { foreach (var edit in e.Edits) { MyAttachmentEditor.GraphicSource = edit.Graphic; break; } } }
