I tried searching but was surprised to not find any good results. Does anyone have a coding pattern to handle "paging" through a large query that exceeds the service's maxRecordCount property? I'd like to find a way to query the record count first, then build a bunch of query tasks with varying start and num properties to retrieve all the results. Promise.all() seems like it'd be what's needed but I can't quite wrap my head around how to make it all work. Here's my related question regarding distinct values that started this.
Blake,
You can use QueryTask.exectueForCount() and in the Query object you can use returnDistinct. This will allow you to get a number that is in fact the real distinct count for your query. You then can decide if you need to use the paging route. Also the query result returns a exceededTransferLimit property that tells you if your results are not all the distinct data.
Interesting approach, thanks. My feature layer (hosted at 10.5.1) doesn't have a maxRecordCount property. It doesn't even have a capabilities property. Any thoughts on that?
After posting I got something that I think works. Besides the fact it doesn't work with returnDistinctValues (as I mentioned before), I'm not sure how I feel about it.
<SPAN class="keyword token">var</SPAN> maxRecordCount <SPAN class="operator token">=</SPAN> <SPAN class="number token">1000</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN>url <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fserver%2Farcgis%2Frest%2Fservices%2FServiceName%2FMapServer%2F0" target="_blank">http://server/arcgis/rest/services/ServiceName/MapServer/0</A><SPAN>'</SPAN></SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> queryParams <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'someFieldName'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> where<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'someFieldName is not null'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForCount</SPAN><SPAN class="punctuation token">(</SPAN>queryParams<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>queryRecordCount<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> pageCount <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ceil</SPAN><SPAN class="punctuation token">(</SPAN>queryRecordCount <SPAN class="operator token">/</SPAN> maxRecordCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> resultPages <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> pageCount<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> resultPages<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">*</SPAN> maxRecordCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> Promise<SPAN class="punctuation token">.</SPAN><SPAN class="token function">all</SPAN><SPAN class="punctuation token">(</SPAN>resultPages<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>resultPageStart<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> queryParams<SPAN class="punctuation token">.</SPAN>start <SPAN class="operator token">=</SPAN> resultPageStart<SPAN class="punctuation token">;</SPAN> queryParams<SPAN class="punctuation token">.</SPAN>num <SPAN class="operator token">=</SPAN> maxRecordCount <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>queryParams<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>featureSets<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// collect features from each FeatureSet</SPAN> <SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> featureSets<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> features <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">concat</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">// do something with array of features</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Here is how I do that:
<SPAN class="keyword token">var</SPAN> iMaxRecords <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> featuresProcessed <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> featuresTotal <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> maxRecordCount <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN>maxRecordCount<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//normally 1000</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN>uri<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> cntQuery <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> cntQuery<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1=1"</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForCount</SPAN><SPAN class="punctuation token">(</SPAN>cntQuery<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>count<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> featuresTotal <SPAN class="operator token">=</SPAN> count<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>count <SPAN class="operator token"><=</SPAN> maxRecordCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//not an issue where you need to page</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> query<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>objectIds <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1=1"</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForIds</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> onSearchIdsFinish<SPAN class="punctuation token">,</SPAN> onSearchError<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">onSearchIdsFinish</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> objectIdsArray <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">;</SPAN> featuresTotal <SPAN class="operator token">=</SPAN> objectIdsArray<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>objectIds <SPAN class="operator token">=</SPAN> objectIdsArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">slice</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> maxRecordCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> onSearchFinish<SPAN class="punctuation token">,</SPAN> onSearchError<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'onSearchIdsFinish returned zero length'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> isQuerying <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> esc <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">onSearchFinish</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// do something with the results</SPAN> featuresProcessed <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> featureSet<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>iMaxRecords <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> iMaxRecords <SPAN class="operator token">=</SPAN> featuresProcessed<SPAN class="punctuation token">;</SPAN> iStart <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> iMaxRecords<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>iStart <SPAN class="operator token"><</SPAN> objectIdsArray<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//If we get this far we need to requery the server for the next lot of records</SPAN> query<SPAN class="punctuation token">.</SPAN>objectIds <SPAN class="operator token">=</SPAN> objectIdsArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">slice</SPAN><SPAN class="punctuation token">(</SPAN>iStart<SPAN class="punctuation token">,</SPAN> iStart <SPAN class="operator token">+</SPAN> iMaxRecords<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> onSearchFinish<SPAN class="punctuation token">,</SPAN> onSearchError<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> iStart <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> iMaxRecords<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
