Hi All,
We are trying to implement remote instantiation of a python application that uses arcpy. The scripts work perfectly fine when running on the virtual machine when logged in as a user. However when using Ansible and TeamCity the script will no longer allow the import of arcpy. Attempting to add arcinfo also creates problems.
Other things of note, I have confirmed that the PYTHONPATH's are configured correctly and that the output for the active user is also the same when running locally or remotely.
I have done a license check and this also reports to have arcInfo "Available"
Any advice appreciated
Importing ArcInfo
# C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcinfo.pyc matches C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcinfo.py
[15:38:05][Step 2/2] import arcinfo # precompiled from C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcinfo.pyc
[15:38:05][Step 2/2] import arcgisscripting # dynamically loaded from C:\Program Files (x86)\ArcGIS\Desktop10.2\bin\arcgisscripting.pyd
[15:38:05][Step 2/2] Traceback (most recent call last):
[15:38:05][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\runpy.py", line 162, in _run_module_as_main
[15:38:05][Step 2/2] "__main__", fname, loader, pkg_name)
[15:38:05][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\runpy.py", line 72, in _run_code
[15:38:05][Step 2/2] exec code in run_globals
[15:38:05][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\site-packages\end_to_end_inspections\out\test.py", line 10, in <module>
[15:38:05][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcinfo.py", line 18, in <module>
[15:38:05][Step 2/2] gp.setProduct("ArcInfo")
[15:38:05][Step 2/2] RuntimeError: ERROR 999999: Error executing function.
Importing arcpy:
# C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.pyc matches C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py
[15:26:38][Step 2/2] import arcpy.geoprocessing._base # precompiled from C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.pyc
[15:26:38][Step 2/2] Traceback (most recent call last):
[15:26:38][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\runpy.py", line 162, in _run_module_as_main
[15:26:38][Step 2/2] "__main__", fname, loader, pkg_name)
[15:26:38][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\runpy.py", line 72, in _run_code
[15:26:38][Step 2/2] exec code in run_globals
[15:26:38][Step 2/2] File "C:\Python27\ArcGIS10.2\lib\site-packages\end_to_end_inspections\out\test.py", line 11, in <module>
[15:26:38][Step 2/2] import arcpy.toolbox
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\__init__.py", line 21, in <module>
[15:26:38][Step 2/2] from arcpy.geoprocessing import gp
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\__init__.py", line 14, in <module>
[15:26:38][Step 2/2] from _base import *
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 592, in <module>
[15:26:38][Step 2/2] env = GPEnvironments(gp)
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 589, in GPEnvironments
[15:26:38][Step 2/2] return GPEnvironment(geoprocessor)
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 545, in __init__
[15:26:38][Step 2/2] self._refresh()
[15:26:38][Step 2/2] File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 547, in _refresh
[15:26:38][Step 2/2] envset = (set(env for env in self._gp.listEnvironments()))
[15:26:38][Step 2/2] RuntimeError: NotInitialized
