I'm trying to create and if/else loop for three sublayers in a group layer. If it's the group layer (0) then the sublayers have certain labels. If it's group layer (4) then the sublayers have other labels, etc.
Here's what I've tried. I've also tried arrays [0] instead of '0'.
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>identifyParams<SPAN class="punctuation token">.</SPAN>layerIds <SPAN class="operator token">===</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>layerName <SPAN class="operator token">===</SPAN> <SPAN class="string token">'10% Damage Risk'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
layerLabel <SPAN class="operator token">=</SPAN> <SPAN class="string token">'24 Hour Forecast'</SPAN><SPAN class="punctuation token">;</SPAN>
label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"10% Damage Risk"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>layerName <SPAN class="operator token">===</SPAN> <SPAN class="string token">'90% Apple Damage Risk'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"90% Apple Damage Risk"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>layerName <SPAN class="operator token">===</SPAN> <SPAN class="string token">'Overall Damage Risk'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Possible Damage"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>identifyParams<SPAN class="punctuation token">.</SPAN>layerIds <SPAN class="operator token">===</SPAN> <SPAN class="string token">'4'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
layerLabel <SPAN class="operator token">=</SPAN> <SPAN class="string token">'48 Hour Forecast'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I've also tried, but it didn't work.
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>layerName <SPAN class="operator token">===</SPAN> <SPAN class="string token">'24 Hour Forecast'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
