release/ src/ - index.html - js/ - stylesheets/ - templates/
/** * This is the build file I have started using * to build my ArcGIS JS API 3.0 apps, which are * based on Dojo 1.7. I used a similar build file * when I was using Require.js, so it wasn't much different. * * I tried using the Dojo Build Tools, but it just seemed * way too bloated to download the Dojo SDK, sort my files, * blah blah blah. With r.js I can use Node NPM to * npm install requirejs and just use the following command * r.js -o src/js/app.build.js * Done and done! * * This build file is meant to be used with r.js * http://requirejs.org/docs/optimization.html * * For more details on options, you can review * the sample r.js build file * https://github.com/jrburke/r.js/blob/master/build/example.build.js */ ({ appDir : "../", baseUrl : "js", dir : "../../release", paths : { "jquery" : 'libs/jquery/jquery-1.7.2.min', "jqueryui" : 'libs/jqueryui/jquery-ui-1.8.20.custom.min', "jquery.boostrap" : 'libs/boostrap/bootstrap.min', "underscore" : 'libs/lodash/lodash.min', "backbone" : 'libs/backbone/backbone-min', /** * This is key. Since the namespaces of dojo & esri, * even dojox and dijit come from the ArcGIS CDN, use the * empty: scheme so r.js doesn't try pull in these * dependencies. * http://requirejs.org/docs/optimization.html#empty */ "dojo" : "empty: ", "esri" : "empty: ", "text" : "empty:" }, /** * r.js uses uglifyjs by default. * https://github.com/mishoo/UglifyJS/ * * If you run r.js via java, you can use google closure. * I tried to integrate closure, but java on my work * machine kept punching me in the face. Stick with uglify, * a dude on twitter told me it was faster anyway. */ optimize : "uglify", /** * This doesn't work as intended for me. * According to docs and google groups, this * should remove all combined files when * optimizing a whole project */ //removeCombined : true, /** * This option will grab all the text! calls and * place them in your optimized file to avoid * making XMLHttpRequests to load the files */ inlineText : true, /** * This is optional, as setting the modules * will create a combined file of all dependencies * in the release folder. You get a single larger file * to load rather than multiple smaller files. * Use at your own discretion. * */ modules : [ { /** * I optimze my app file, because I use * my main file to set up my dojoConfig. * If doing a single js file optimization, * DO NOT include the dojoConfig file * to be included. It will blow you up. * Optmize the next entry point into your app. */ name: "app" } ], /** * Will make your css a single line file */ // I had an issue in one app where this caused some issues. Didn't track it down, but only // happened in the one app. I should look into it further. Just disable if it causes problems. optimizeCss : "standard", /** * Ewww, RegEx. It's easy though, * just include files/folders you don't want to * get exported to your release build folder. */ fileExclusionRegExp : /\.(coffee|coffee~|js~|html~|css~|swp|rb|lnk)|sass|.sass-cache|build/ })
