I received shape files, and imported it. I can see the shapes, but I need to export the cordinate points of the shape to an excel or csv file in order to import into another program.
If you are looking for the XY coordinates of Centroid of polygons, you could add two Fields to Attribute Table, viz, X and Y and use Calculate Geometry to populate the fields with the X and Y coordinate of the Centroid. Then you can use Table to Excel geoprocessing tool to export to Excel.
But, if you want the XY coordinates of all the vertices of the polygon, you will need to convert feature vertices to points, add the XY fields to attribute table and populate using Calculate Geometry. Then Go for Table to Excel.
For all points for all license levels, there are other workarounds
The key is the explode_to_points which busts up the geometry into its constituent points. Rows 1 to 5 form the clockwise points of a square in this example. Once busted up, bring it back in as table and export to excel, or there are tools to simply send the array to excel directly...
Hi Dan,
Is it possible to export the coordinates of vertices of a polygon into excel or as a text file in the following format: Polygon1: y,x ; y,x ;y,x ; y,x
Therefore, all coordinates that make up a polygon should be in one row?
Liesl Not without coding the output to from numpy to a row format. If you have a use case, you might want to start another question describing the need to go to excel and why WKT or similar output format is needed
Hi Liesl De Swardt ,
I guess you could do something like this with a bit of Python code:
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">import</SPAN> arcpy fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\WKT\data.gdb\polygons'</SPAN> <SPAN class="comment token"># the input polygons</SPAN> fld_id <SPAN class="operator token">=</SPAN> <SPAN class="string token">'OID@'</SPAN> <SPAN class="comment token"># use the OID as ID field in the output</SPAN> txt <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\WKT\output2.txt'</SPAN> <SPAN class="comment token"># teh output text file to load into Excel</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>txt<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'w'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> f<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>fld_id<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> curs<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> curs<SPAN class="punctuation token">:</SPAN> polygon <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> result <SPAN class="operator token">=</SPAN> GetYXcrdList<SPAN class="punctuation token">(</SPAN>polygon<SPAN class="punctuation token">.</SPAN>WKT<SPAN class="punctuation token">)</SPAN> f<SPAN class="punctuation token">.</SPAN>write<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{}\t{}\n"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">GetYXcrdList</SPAN><SPAN class="punctuation token">(</SPAN>wkt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> wkt <SPAN class="operator token">=</SPAN> wkt<SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MULTIPOLYGON ((('</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">')))'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN> lst <SPAN class="operator token">=</SPAN> wkt<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">','</SPAN><SPAN class="punctuation token">)</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN> <SPAN class="keyword token">for</SPAN> crd <SPAN class="keyword token">in</SPAN> lst<SPAN class="punctuation token">:</SPAN> xy <SPAN class="operator token">=</SPAN> crd<SPAN class="punctuation token">.</SPAN>strip<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">' '</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> result <SPAN class="operator token">==</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">:</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{},{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>xy<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> xy<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> result <SPAN class="operator token">+=</SPAN> <SPAN class="string token">";{},{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>xy<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> xy<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> result <SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">'__main__'</SPAN><SPAN class="punctuation token">:</SPAN> main<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Just change:
Below the result of a test run:
What do you want to do with this list of Lat, Lon coordinates in Excel?
i cant run this code
Xander Bakker
if you can make a video for this code, it will be great....
