I have a feature services published with a point layer and a table. They are related via a primary/foreign key and have an established relationship class. The feature service is published pointing to version A which is one level under Default. Version B is under version A.
Default -> A -> B
I run the queryRelatedRecords method on the point layer referencing the relationshipID of the table. I have some records returned as expected.
I run the queryRelatedRecords method on the point layer referencing the relationshipID of the table and give it gdbVersion = A. I have some records returned, same result as no gdbVersion.
I run the queryRelatedRecords method on the point layer referencing the relationshipID of the table and give it gdbVersion = B. I have the same records returned as if I did not use the gdbVersion option or handed it version A.
I run the queryRelatedRecords method on the point layer referencing the relationshipID of the table and give it gdbVersion = C (which doesn't exist). No records are returned and an error message is presented.
Is anyone able to confirm this behavior or if a bug exists? I am using ArcGIS Server 10.21 on Windows.
Thanks.
