I am not quiete sure if I am right in this discussion group.
I have written an Add-On for ArcCatalog (Button) which allows me to add data into a filegeodatabase.
The import of the data into the tool takes about 5 second. The import into the filegeodatabase takes about 5 hours. Maybe someone can have a look at the sourcecode and tells me what to do to get the imort faster.
Option Explicit On
Imports ESRI.ArcGIS.Catalog
Imports ESRI.ArcGIS.CatalogUI
Imports ESRI.ArcGIS.Display
Imports ESRI.ArcGIS.DataSourcesGDB
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Geometry
Imports System.Xml
Imports System
' Structure für eine Haltung
Structure Haltung
Public bezeichnung As String
Public projekt As String
Public gebiet As String
Public baujahr As String
Public lage As String
Public entwaesserung As String
Public baustatus As String
Public bodenart As String
Public strasse As String
Public anfangsschacht As String
Public endschacht As String
Public koordinaten As ESRI.ArcGIS.Geometry.Polyline
Public historischerName As String
Public anfangshoehe As Double
Public endhoehe As Double
Public material As String
Public durchmesser As String
Public laenge As Double
Public bemerkungen As String
Public zustand As String
Public letzteBefahrung As String
Public videoBefahrung As String
Public pdfBefahrung As String
End Structure
' ... some more code
Public Class kanalXMLImport
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Protected Overrides Sub OnClick()
Try
' Herstellen einer Verbindung zur Geodatabase
Dim pWorkspaceFactory As IWorkspaceFactory = New ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactory
Dim pWorkspace As IWorkspace = pWorkspaceFactory.OpenFromFile(gdbDialogErg.FullName, 0)
' Einlesen des Dataset 'Kanalkataster'
Dim featureWorkspace As IFeatureWorkspace = TryCast(pWorkspace, IFeatureWorkspace)
Dim pDataSet As IDataset = featureWorkspace.OpenFeatureDataset("Kanalkataster")
' Durchlaufen aller Unterpunkte
Dim pEnumDatasubsets As IEnumDataset = pDataSet.Subsets
Dim pDatasubset As IDataset = pEnumDatasubsets.Next()
While pDatasubset IsNot Nothing
Select Case pDatasubset.Name
Case "SW_Haltungen"
MsgBox("SW-Haltungen")
If Not importHaltungen(pDatasubset, SW_Haltungen) Then
'Beenden der Methode
Exit Sub
End If
' Nächster Datensatz
pDatasubset = pEnumDatasubsets.Next()
End While
'Alle Daten erfolgreich eingelesen
MsgBox("Alle Daten erfolgreich importiert", MsgBoxStyle.Information, "Importieren erfolgreich")
' Abfangen eines evtl. auftretenden Fehlers
Catch ex As Exception
MsgBox("Fehler beim Importieren " & ex.Message)
Exit Sub
End Try
My.ArcCatalog.Application.CurrentTool = Nothing
End Sub
' Funktion zum Importieren der Haltungsdaten in die GeoDatabase
' Liefert true/false je nachdem ob erfolgreich
Private Function importHaltungen(ByRef pDataset As IDataset, ByRef haltungen As List(Of Haltung)) As Boolean
Dim pTable As ITable = Nothing
Try
' Casten in ein iTable
pTable = TryCast(pDataset, ITable)
' Löschen aller vorhandener Einträge
pTable.DeleteSearchedRows(Nothing)
' Für alle zu importierenden Haltungen
For Each haltung As Haltung In haltungen
' Anlegen einer neuen Zeile
Dim ds As IRow = pTable.CreateRow()
' Für alle Spalten in der Tabelle
For i As Integer = 0 To ds.Fields().FieldCount - 1
' Je nach Spalte werden die Eigenschaften gesetzt
Select Case ds.Fields().Field(i).Name.ToLower
Case "shape"
ds.Value(i) = haltung.koordinaten
Case "bezeichnung"
ds.Value(i) = haltung.bezeichnung
Case "historische_bezeichnung"
ds.Value(i) = haltung.historischerName
Case "anfangsschacht"
ds.Value(i) = haltung.anfangsschacht
Case "endschacht"
ds.Value(i) = haltung.endschacht
Case "durchmesser"
ds.Value(i) = haltung.durchmesser
Case "material"
ds.Value(i) = haltung.material
Case "baujahr"
ds.Value(i) = haltung.baujahr
Case "lage"
ds.Value(i) = haltung.lage
Case "strasse"
ds.Value(i) = haltung.strasse
Case "gebiet"
ds.Value(i) = haltung.gebiet
Case "status"
ds.Value(i) = haltung.baustatus
Case "bemerkungen"
ds.Value(i) = haltung.bemerkungen
Case "zustand"
ds.Value(i) = haltung.zustand
Case "letztebefahrung"
If haltung.letzteBefahrung <> "" Then
Dim ij As Long
End If
ds.Value(i) = haltung.letzteBefahrung
Case "videobefahrung"
ds.Value(i) = haltung.videoBefahrung
Case "pdfbefahrung"
ds.Value(i) = haltung.pdfBefahrung
End Select
' Speichern des Datensatzes
ds.Store()
' Alles erfolgreich -> Rückgabe true
Return True
' Abfangen eines evtl. Fehlers
MsgBox("Fehler beim Importieren der Haltungen" & ControlChars.CrLf & "Lfd.-Haltung: " & pTable.RowCount(Nothing) + 1 & ControlChars.CrLf & ex.Message, MsgBoxStyle.Critical, "Fehler beim Importieren der Haltungen")
' Beenden der Funktion
Return False
End Try
End Function
End Class<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>My importHaltungen() has to add abaout 1600 objects and it tooks about 30 minutes to do so.
My only idea is to put the gdb to the local-drive insteadt of a network-drive
