<esri:Map x:Name="MyMap" Extent="-16574645.619,-5541958.774,13341035.686,10559275.713" Loaded="MyMap_Loaded" esri:Editor.SnapDistance="30" MouseClick="MyMap_MouseClick" MouseMove="MyMap_MouseMove" MouseLeftButtonUp="MyMap_MouseLeftButtonUp" MouseRightButtonDown="MyMap_OnMouseRightButtonDown">
private void MyMap_OnMouseRightButtonDown(object sender, MouseButtonEventArgs e) { PointCollection pointCollection = new PointCollection { new MapPoint(0, 0), MyMap.ScreenToMap(e.GetPosition(MyMap)) }; Polyline polyline = new Polyline(); polyline.Paths.Add(pointCollection); Graphic graphic = new Graphic { Symbol = LayoutRoot.Resources["MyScaleBox"] as ESRI.ArcGIS.Client.Symbols.Symbol, Geometry = polyline }; ((GraphicsLayer)MyMap.Layers["MyGraphicsLayer"]).Graphics.Add(graphic); ((GraphicsLayer)MyMap.Layers["MyGraphicsLayer"]).Refresh(); }
<Grid x:Name="LayoutRoot" Background="White"> <Grid.Resources> <esri:SimpleFillSymbol x:Key="RedFillSymbol" Fill="#66FF0000" BorderBrush="Red" BorderThickness="2" /> </Grid.Resources> <Grid.ColumnDefinitions> <ColumnDefinition/> <ColumnDefinition/> </Grid.ColumnDefinitions> <esri:Map x:Name="MyMap" WrapAround="True" Background="White"> <esri:ArcGISTiledMapServiceLayer ID="PhysicalTiledLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/NGS_Topo_US_2D/MapServer"/> <esri:GraphicsLayer ID="MyLayer" MouseLeftButtonDown="GraphicsLayer_MouseLeftButtonDown" Initialized="GraphicsLayer_Initialized"> <esri:GraphicsLayer.Graphics> <esri:Graphic Symbol="{StaticResource RedFillSymbol}"> <esri:Polygon > <esri:Polygon.Rings> <esri:PointCollection> <esri:MapPoint X="110.039" Y="-20.303" /> <esri:MapPoint X="132.539" Y="-7.0137" /> <esri:MapPoint X="153.281" Y="-13.923" /> <esri:MapPoint X="162.773" Y="-35.174" /> <esri:MapPoint X="133.594" Y="-43.180" /> <esri:MapPoint X="111.797" Y="-36.032" /> <esri:MapPoint X="110.039" Y="-20.303" /> </esri:PointCollection> </esri:Polygon.Rings> </esri:Polygon> </esri:Graphic> </esri:GraphicsLayer.Graphics> </esri:GraphicsLayer> </esri:Map> <esri:Map x:Name="MirroredMap" Grid.Column="1" /> </Grid>
EditGeometry editGeometry; public MainPage() { InitializeComponent(); editGeometry = new EditGeometry(MyMap); editGeometry.IsEnabled = true; MyMap.ExtentChanged += (s, e) => { MirroredMap.Extent = MyMap.Extent; }; MyMap.Layers.LayersInitialized += (s, e) => { foreach (var l in MyMap.Layers) { if (l is ArcGISTiledMapServiceLayer) { MirroredMap.Layers.Add(new ArcGISTiledMapServiceLayer() { ID = l.ID, Url = (l as ArcGISTiledMapServiceLayer).Url }); } else if (l is GraphicsLayer) { var graphicsLayer = new GraphicsLayer() { ID = l.ID }; if ((l as GraphicsLayer).Graphics != null) { foreach (var g in (l as GraphicsLayer).Graphics) { g.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(g_PropertyChanged); var clonedGraphic = new Graphic() { Geometry = Geometry.Clone(g.Geometry), Symbol = g.Symbol }; foreach (var item in g.Attributes) clonedGraphic.Attributes[item.Key] = item.Value; graphicsLayer.Graphics.Add(clonedGraphic); } } MirroredMap.Layers.Add(graphicsLayer); } } }; } void g_PropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e) { if (e.PropertyName == "Geometry") { var graphic = sender as Graphic; var layer = MirroredMap.Layers["MyLayer"] as GraphicsLayer; var clonedGraphic = layer.Graphics.FirstOrDefault(g => (int) g.Attributes["ObjectID"] == (int) graphic.Attributes["ObjectID"]); clonedGraphic.Geometry = Geometry.Clone(graphic.Geometry); } } private void GraphicsLayer_MouseLeftButtonDown(object sender, GraphicMouseButtonEventArgs e) { editGeometry.StartEdit(e.Graphic); } private void GraphicsLayer_Initialized(object sender, EventArgs e) { var l = sender as GraphicsLayer; int i = 0; foreach (var g in l.Graphics) { g.Attributes["ObjectID"] = ++i; } }
if (e.Action == EditGeometry.Action.VextedMoved || e.Action == EditGeometry.Action.VertexAdded) { editGeometry.StopEdit(); editGeometry.StartEdit(editGraphic); } else if(e.Action == EditGeometry.Action.EditCompleted) layer.Refresh();
