We are using Survey123 on an ipad and using a Bad Elf external GPS
The GPS is definitely connected to the ipad as i can see the position in the ios bad elf app
All documentation says that survey 123 will use the bad elf positioning however
the x y and accuracy are different in survey123
I am pulling data so that the x y and accuracy info is populating a field within the survey. The accuracy in the survey is often 5 or 10 (no decimal places), however the bad elf is showing sub meter accuracy to 2 decimal places.
In the survey the x, y and accuracy are 'decimal' and I have copied the methodolgy for pulling data from the location - pulldata("@geopoint", ${location},"horizontalAccuracy")
I will hide the field so that the users cant see this discrepency but am concerned we have wasted our money on bad elfs if they are not being used within survey123
Has anyone else had survey123/ios/Bad Elf issues?
Thankyou
John
