Hello,Im trying to write a code that will be used as a tool on arcgis. The user will have to insert the number of a Block and the Number of a Parcel in 1 shapefile and the tool will create a JPEG map of the Block and Parcel. The 1st thing i need to do is to select the correct Parcel and Block (Gush = Block, Helka = Parcel). The field for Gush in the shapefile is "GUSH_NUM", and the field for Helka is "Parcel"So both Gush and Helka will have to be arcpy.GetParameterAsText, and using a variable in the where clause of the select by attribute tool. But how do i write it in the where clause of the select by attribute tool? I tried using this post for help: http://forums.arcgis.com/threads/20459-Select-By-Attributes-using-a-variable-in-the-Where-clause?highlight=Select+attributesSo i tried writing the where clause as the post suggests but it still doesnt work. I get an error - invalid expression.Here is my code so far, i tried only on the Gush for now. Will apriciate any help. 🙂# Import the arcgisscripting module. import arcpy # Setting the Variabls. # Input gush and Helka. Gush = arcpy.GetParameterAsText(0) Helka = arcpy.GetParameterAsText(1) # Output Location (the folder where the resualt will be saved). Workspace = arcpy.GetParameterAsText(2) arcpy.env.workspace = Workspace hel_openland_shp = "W:\\Av_data\\cover_new\\mamag_mapi\\hel_openland.shp" Output_Layer = "hel_openland_Layer" arcpy.MakeFeatureLayer_management(hel_openland_shp, Output_Layer) arcpy.SelectLayerByAttribute_management(Output_Layer, "NEW_SELECTION", "\"GUSH_NUM\" = " + "'" + Gush + "'")
