Hi, I'm trying to convert and optimize the Ianko PolylineGetAzimut function to meet our requirements and i'm having problem to extract the line with the getpart method. I'm got this error message when I run the function : AttributeError: 'function' object has no attribute 'shape'.Thanks you
import arcpy
import math
def polyline_Get_Azimuth(azimut):
#try:
#pGeometry = params.Geometry
fc = "C:\Temp\Generation_Direction\Montreal_Ouest_Test2.shp"
#fc = arcpy.GetParameterAsText(0)
dDistance = 0.5
desc = arcpy.Describe(fc)
### V?rifier si les champs Azimut et Orientation sont pr?sent
shapefieldname = desc.ShapeFieldName
fieldnames = []
fields = arcpy.ListFields(fc)
for field in fields :
print("Field: {0}".format(field.name))
#fieldnames.format(field.name)
#print fieldnames
#field = fields.next()
if "Azimut" not in fieldnames:
arcpy.AddField_management(fc,"Azimut","DOUBLE")
if "Orientatio" not in fieldnames :
arcpy.AddField_management(fc,"Orientatio","TEXT","","","1")
### V?rification du type de format du shapefile
type = desc.shapetype
#if fc.IsEmpty:
#return -1
#arcpy.AddMessage("Le fichier est vide")
#else:
#if pGeometry.GeometryType != ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline:
if type != "Polyline":
arcpy.AddMessage("Le fichier n'est pas du type polygone")
#return -1
rows = arcpy.SearchCursor(fc)
pPolyline = fc
Pi = 4 * math.tan(1)
#pLine = ESRI.ArcGIS.Geometry.Line()
pLine = fc.getPart(0)
dLength = pPolyline.Length
pPolyline.QueryTangent(0, dDistance, True, dLength, pLine)
dAngle = pLine.Angle * 360 / (2 * Pi)
if (dAngle < 90):
dAngle = 90 - dAngle
else:
dAngle = 450 - dAngle
return dAngle
#Process the lines
row = rows.next()
for row in rows:
outshape = row.shape
row.Azimut = dAngle
#while row:
#if geodesic:
#utshape = row.shape
#[Orientatio,Azimut] = azimut(outshape)
#arcpy.AddMessage('!: %s,%s'%(sdmbearing,sdmazimuth))
#row.Orientatio = Orientatio
#row.Azimut = Azimut
#else:
#pass #map_azimuth(inrow.shape)
#rows.updaterow(row)
#row = rows.next()
rows.updaterow(row)
row = rows.next()
