function showResults(featureSet) { //remove all graphics on the maps graphics layer map.graphics.clear(); //******* add this console.log(featureSet); console.log(featureSet.length); //******* //QueryTask returns a featureSet. Loop through features in the featureSet and add them to the map. //Performance enhancer - assign featureSet array to a single variable. var resultFeatures = featureSet.features; //****** add this console.log(resultFeatures); // im guessing this may be undefined. or an unexpected value console.log(resultFeatures.length); //****** for (var i=0, il=resultFeatures.length; i<il; i++) { //Get the current feature from the featureSet. //Feature is a graphic var graphic = resultFeatures; graphic.setSymbol(symbol); //Set the infoTemplate. graphic.setInfoTemplate(infoTemplate); //Add graphic to the map graphics layer. map.graphics.add(graphic); } }
queryTask.execute(query,showResults);
queryTask.execute(query,showResults,showErr);
function showErr(){ console.log('error in query execution'); }
function showResults(featureSet) { //remove all graphics on the maps graphics layer map.graphics.clear(); //******* add this console.log(featureSet); console.log(featureSet.length); //******* ///all the rest of your code
Hi lowgas,Thanks for the replay!I tried your code. But that does not display the attributes and geometry. And Firefox Firebug shows me no errors.I do not understand what the problem is. I saw many examples in internet.and I downloaded one of they and tried without the images. e.g. http://resources.esri.com/arcgisserver/apis/javascript/arcgis/index.cfm?fa=codeGalleryDetails&scriptID=16041. I just wanted to try with attrubutes and geometry.I published the file PhotoLocations.mxd to my arcgisserver as map service and used for javascript code. I think basically this shoud work. I see the map, but no infowindow with attributes as before. I wonder....if this example works right with you, I pehaps have problem with the publishing of map service.<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <title>QueryTask with geometry, results as an InfoWindow onHover containg image</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.2/js/dojo/dijit/themes/tundra/tundra.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.2"></script> <script type="text/javascript" language="Javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.query"); function init() { var startExtent = new esri.geometry.Extent(-117.197, 34.035, -117.183, 34.045, new esri.SpatialReference({wkid:4326})); //create map var map = new esri.Map("mapDiv",{extent:startExtent}); //listen for when map is loaded and then add query functionality dojo.connect(map, "onLoad", initFunctionality); //create and add new layer var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"); map.addLayer(layer); var overlaymap=new esri.layers.ArcGISDynamicMapServiceLayer("http://myserver/ArcGIS/rest/services/PhotoLocations/MapServer"); map.addLayer(overlaymap); } function initFunctionality(map) { //build query task var queryTask = new esri.tasks.QueryTask("http://myserver/ArcGIS/rest/services/PhotoLocations/MapServer/0"); //build query filter var query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["OID", "EXIF_ImageDescription", "EXIF_Copyright", "SourceFileName"]; query.where = "OID >= 0"; var infoTemplate = new esri.InfoTemplate(); infoTemplate.setTitle("${SourceFileName}"); infoTemplate.setContent("<b>Description: </b>${EXIF_ImageDescription}<br/>" + "<b>Copyrights: </b>${EXIF_Copyright}<br/>"); map.infoWindow.resize(225,350); //Can listen for onComplete event to process results or can use the callback option in the queryTask.execute method. dojo.connect(queryTask, "onComplete", function(featureSet) { map.graphics.clear(); var highlightSymbol = new esri.symbol.PictureMarkerSymbol("images/i_camera.png", 40, 40); var symbol = new esri.symbol.PictureMarkerSymbol("images/i_camera.png", 40, 40); //QueryTask returns a featureSet. Loop through features in the featureSet and add them to the map. for (var i=0, il=featureSet.features.length; i<il; i++) { //Get the current feature from the featureSet. //Feature is a graphic var graphic = featureSet.features; graphic.setSymbol(symbol); graphic.setInfoTemplate(infoTemplate); //Add graphic to the map graphics layer. map.graphics.add(graphic); } map.graphics.enableMouseEvents(); dojo.connect(map.graphics, "onMouseOver", function(evt) { var content = evt.graphic.getContent(); map.infoWindow.setContent(content); var title = evt.graphic.getTitle(); map.infoWindow.setTitle(title); evt.graphic.setSymbol(highlightSymbol); map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); }); dojo.connect(map.graphics, "onMouseOut", function(evt) { map.infoWindow.hide(); evt.graphic.setSymbol(symbol); }); }); queryTask.execute(query); } dojo.addOnLoad(init); </script> </head> <body class="tundra"> Hover over a camera icon to see image thumbnail and image description. <div id="mapDiv" style="width:1000px; height:800px; border:1px solid #000;"></div> </body></html>
