Hi muralimohana_c,You can edit the content of the directions file manually, since those are in plain XML. The file you need to localize is located under %ArcGIS Installation folder%\Desktop10.0\NetworkAnalyst\Directions\resources.xml.The Supported Languages (codes) are: Chinese (zh-CN) Danish (da-DK) Dutch (nl-NL) English (en-US) - default language French (fr-FR) German (de-DE) Italian (it-IT) Japanese (ja-JP) Norwegian (no-NO) Portuguese (pt-PT) Spanish (es-ES) Swedish (sv-SE) As far as I understand, this is only for managing the non-Latin symbols properly because you don't have to change the "Language ID" tag's value when making edits to the directions tags' text values.However, this is a pretty big and tedious task - to translate all the text in the tags and make sure it makes sense when routing. So, as Alan from Esri mentioned earlier, it is best to contact a local Esri distributor and if you are on maintenance you should have no problem obtaining a translated directions file which you then could use.
