Hello
Everyone
I have a problem to get the subtypes from tables in arcmap with the arcobjects library in C# (sharp) lenguage.
So i need that someone could help me with some code example.
Appreciating the attention
Have a look at this page on the API help file, whilst it's about creating subtypes you should be able to figure out how to access existing subtypes.
<CODE><SPAN class="" style="color: #0000ff;">public</SPAN> <SPAN class="" style="color: #0000ff;">void</SPAN> GetSubtypes(IFeatureClass featureClass) { <SPAN class="" style="color: #008000;">// Cast the feature class to the ISubtypes interface.</SPAN> ISubtypes subtypes = (ISubtypes)featureClass; <SPAN class="" style="color: #008000;">// then you can enumeraate subtypes.</SPAN> IEnumSubtype enumSubtype = subtypes.Subtypes }
You Can Use the Following Code (C#) -
//here item is a IfeatureClass
ISubtypes subtypes = item as ISubtypes;if (subtypes.HasSubtype){IEnumSubtype enumSubtype = subtypes.Subtypes;enumSubtype.Reset();int subcode = -1;string subdesc = enumSubtype.Next(out subcode);while (!string.IsNullOrEmpty(subdesc)){subdesc = enumSubtype.Next(out subcode);
//str3 is a string (empty)str3 = subdesc;
//in this above code you can able to find subtype names associated with each featurelayer
