# Import arcpy module
import arcpy
arcpy.env.workspace = "R:\Karto\Bierer2014\FFH_MEKA\data.gdb"
# Local variables:
ALK_Flurstueck_Merge1 = r"R:\Daten\geo_daten\Basisgeometrien\Basisgeometrien_2014_03_21.gdb\data\ALK_Flurstueck_Merge1"
Meka = "R:\\Karto\\Bierer2014\\FFH_MEKA\\Meka.mdb\\Meka"
ALK_Flurstueck_Merge1_2 = "ALK_Flurstueck_Merge1"
Count_Lines = arcpy.GetCount_management(Meka)
print Count_Lines
MekaLyr = arcpy.MakeTableView_management(Meka)
for i in range(0, 18000, 100):
print i
y = str(i + 99)
print y
z = str(i)
## SelectCl = ( [ID] < ' + y + " AND [ID] > '" + z + ")
arcpy.SelectLayerByAttribute_management(MekaLyr,"NEW_SELECTION", '( [ID] < ' + y + " AND [ID] > " + z + ")")
# Process: Feld verbinden
arcpy.JoinField_management(ALK_Flurstueck_Merge1, "FLSKZ", MekaLyr, "FLRSTKZ", "FLRSTKZ;ALLB-Nr;Antragsteller;'Name, Vorname Antragsteller';Strasse;PLZ;Ort;'Nutzungsfl ar';N-Code;Meka-Codes;Feld11;Feld12;Feld13;Feld14;Feld15;Feld16;Feld17;Feld18;Feld19")
# Process: Features kopieren
arcpy.CopyFeatures_management(ALK_Flurstueck_Merge1_2, "zwErgebnis_" + i, "", "0", "0", "0")
Unfortunately the join doesn't work in one, so I want to split the table and join then?
But I miss the option which offers the arcmap interface - keep only matching records?
With the script here python is working, but nothing happens?
