Is it possible to show multiple features data in a single pop-up?
For example I have 3 layers on click shows 3 pop-ups instead of that I need a single pop up with 3 layers data?
You are right Steve this info should be in the documentation. I'll work on adding a sentence or two to the doc to make this clearer. Nathan - can you tell me a bit more about your use case? Why do you want to display multiple popups? How will users interact with the map to display the popups (clicking a feature, drawing a rectangle)? More details may help us come up with a way for you to display this info. Kelly
Hi Kelly,I suspected that but couldn't find any documentation to back it up. Perhaps the InfoWindow page could be updated to include that?It's kind of hinted by map.infoWindow which says "Displays the InfoWindow on a map" but I can't see any explicit mention of the fact that only 1 infoWindow is supported on the map.Cheers,Steve
Any reason why you couldn't just instantiate your own Popups/InfoWindows? (rather than using the single instance attached to the map)
The Popup and InfoWindow only display one popup at a time
