I would like to update "GISID" whose "Tageget_FID" joint to "JOIN_FID" in the same attributes.
Regards,
Raj
This thread is going nowhere:
Good luck,
I have point Feature and Line Feature. I had updated the Point_Id, whose line touch with Point Feature. I need to update the Point_Id whose line touch with line Feature still the line feature break.
Raj P
Yes...respond on the other thread. I will lock this one if we don't get a response within 24 hours, there are other similar threads on this topic and I suspect it is an attempt to try and float a post to the top of the pile
Guessing is right, I don't really have a clue what the OP is asking. Also, is this just a different flavor of the Update Cursor. post from last week? Sadly, the same OP never replied back to most of the suggestions people offered over there. I am going to take a pass on this one.
Guessing at what you are trying to do...you can't update a table that is joined to another table unless you save to a new file and make the join permanent... if the table you are showing isn't a joined result, then calculate field will work
