Hey Guys
I have a data set Air mass trajectories (excel file) with a lot of points given in decimal degrees. I have plotted the trajectories in Arcmap but I need to know the distance between them. They span more or less from equator to Greenland so there is the issue of different E/W distances.
Regards Kasper
If you do not have Desktop Advanced and the Near GP tool then provided you can deal with 0.5% error then the Haversine formula might be suitable.
Or Vincenty if you want to get fancy.
I don't work with data covering such a large area, but I would suggest km...in any event you probably want the geodesic distances which have new options in 10.2.1 perhaps using the Near tool
converting decimal degrees to miles, kilometers,
This must work, though I never used it
Latitude/Longitude Distance Calculator
Thanks for your answers.
I have tried using the Haversine formula in excel but I can’t get the right distance. I have calculated the following parameter:
R = earth’s radius (mean radius = 6,371km)
Δlat = lat2− lat1
Δlong = long2− long1
a = sin²(Δlat/2) + cos(lat1)*cos(lat2)*sin²(Δlong/2)
c = 2*atan2(√a, √(1−a))
d = R*c (distance)
As described at http://www.ig.utexas.edu/outreach/googleearth/latlong.html
It says on the web-site that angles need to be in radians and I tried with radians calculated from both decimal degrees and degrees, minutes, seconds.
I think Excel does something unusual with ATAN2.
Lat/Lon Distance Excel (Spherical Law of Cosines and Haversine Formula in Excel) | feed on my links
Now I got the Haversine fomula to work so problem solved
Thanks to all of you for your input they really helped.
