Table names are case-insensitive. All comparisons should be done with an insensitiveoperator or by first upcasing both strings.Best practice is to reserve the SDE user for geodatabase administration. Instead ofcreating spatial data as SDE you really ought to create user(s) (with same-namedschemas) to own spatial tables, and user(s) to access it (without the possibility of removing the tables accidentally, or as a result of a DOS attack).- V
I have noticed depending on how and where layers are created in SDE the software changes the capitalization regardless of what I entered as the creation or output name. What problem is it causing you? If trying to set a layer by the source name then I would suggest to uppercase all layer name variables when looking for them, so they will match. Would that help with this situation?Thanks,Sol
