I want to print a map after buffer is completed and show all the highlighted parcels using print widget but I got error message:
Uncaught TypeError: Converting circular structure to JSON
The main code for buffer from here:https://community.esri.com/thread/121140?q=buffer%20results#463851
and use print widget from sample here: https://developers.arcgis.com/javascript/jssamples/widget_print_esri_request.html
Besides that, I also found this thread if you have graphics:
https://community.esri.com/thread/69239
with this solution
var graphic = new esri.Graphic(result.feature.toJson());
But how do you apply it with FeatureLayer or geometry?
Please share you options.
Thank you.
