I have a survey where I need to make a series of responses to a set of questions 'required' based on a response from a previous question. To achieve this I am using a 'relevant' statement that displays the question(s) that are 'required' based on the previous resonse. I would like to apply a formula to the 'required' field that creates the 'yes' in order for it to work.
Testing shows that when I use the 'calculation' field, I can display the result text of the formula if(selected(${result1}, 'PRIMARY'),'yes','no') to be either yes or no. But when I apply the same logic to the 'required' field, the 'required' is not applied. I would like to add this to the survey to ensure that all the 'required' questions are completed, for validation purposes.
Steven
