Hello All,I trying to build flex moblile app where I am using splitNavigator to display a query and map result on two separte views. I am using the findTask to query the data however, I am having some problems displaying the query results on the map view.On the findTask executeComplete event I am running the executeCompleteHandler event using the pushView method to push the graphics to the map, but nothing is being display:private function executeCompleteHandler(event:FindEvent):void { var resultCount:int = event.findResults.length; if (resultCount == 0) { //do something } else { // add feature as graphic to graphics layer for (var i:int = 0; i < resultCount; i++) { findTaskResults.addItem(event.findResults.feature) } var snv:SplitViewNavigator=navigator.parentNavigator as SplitViewNavigator; var mapView:ViewNavigator=snv.getViewNavigatorAt(1) as ViewNavigator; mapView.pushView(map, findTaskResults); } } On the map view, I trying to load the data in the following manner, but I getting an error on the graphic layer dataprovider {data.feature}. <esri:GraphicsLayer graphicProvider="{data.feature}" > <esri:symbol> <esri:SimpleFillSymbol alpha="0.5" color="red"> <esri:outline> <esri:SimpleLineSymbol alpha="1.0" color="yellow"/> </esri:outline> </esri:SimpleFillSymbol> </esri:symbol> </esri:GraphicsLayer>Any help will be appreciated. Thanks all.Koman Diabate
