Asta,Your basemap layer is dynamic so the Map doesn't have any LODs. tiled layers will only display if the map's scale matches a cached scale in the layer. You can force the map to only go to compatible scales by adding LODs in the config.See lods example at:http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Main_configuration_file/01m300000018000000/You can copy the resolution and scale values from the tile info at:http://gis.lmi.is/arcgis/rest/services/kort_isn93/ornefni_kort_isn93/MapServer
Flex Viewer 3.0 Running on ArcGIS 10 Hi everyone, sorry for this newbie question but I'm completely stumped - it's obviously something fundamental that I'm forgetting or not grasping. I have a Parcel polygon layer in SDE. In my MXD I have created a successful relate and created a service in ArcServer. When creating the service I specified a map service as well as a feature service. In my flex viewer, no matter what I try I can't get the layer to display unless I set the Type = "dynamic". When I set it to feature it just doesn't draw. What am I doing wrong? This works: <layer label="Parcels" type="dynamic" visible="true" alpha="1.0" popupconfig="popups/PopUp_Fires.xml" url="http://maps/ArcGIS/rest/services/BaseData/Parcels/MapServer"/> But this doesn't: <layer label="Parcels" type="feature" visible="true" alpha="1.0" popupconfig="popups/PopUp_Fires.xml" url="http://maps/ArcGIS/rest/services/BaseData/Parcels/ MapServer/0"/> **It appears the layer is added to the viewer, I can see it in the "More..." list, and I can 'Zoom to' it. however the polygons just aren't there?? I'm trying to get the feature type to work so that I can use Robert's InfoRelate widget.... Thank you for any guidance....I've been working on this for 5-6 hours now but can't see what I'm doing wrong. Steve
