Is there a fix for ArcReader 10.1? I'm installing it on a new win7 machine and it won't connect to ArcServer data though shapefiles are fine. I don't see an SQL Native client folder on the 10.1 install disk though. Something changed? This works fine on all the other PCs, though those were upgraded from ArcReader 10.0
I figured out a fix for this; I went from a direct connect to an SDE service connection for the source data in my ArcMap project and ArcReader 10 was able to access the PMF fine. I was using direct connect with the 9.3 ArcReader and it worked fine. I know direct connect is the recommended method of connecting but when building a project to publish for ArcReader 10 you might want to consider the SDE service connection instead.
