Sub PopulateListBoxMUTCDPage Dim objRS4, objSelLayer4, objEFPageOneControls4, objEditForm4 Set objSelLayer4 = Map.SelectionLayer Set objRS4 = objSelLayer4.Records objRS4.Bookmark = Map.SelectionBookmark Set objEditForm4 = application.map.layers("Supports").forms("EDITFORM") Set objEFPageOneControls4 = objEditForm4.Pages("page3").Controls Dim MUTCD_CodeValue MUTCD_CodeValue = objEFPageOneControls4("mutcd_code").Value 'msgbox MUTCD_CodeValue objEFPageOneControls4("List1").Clear ' SPECIFY THE PATH TO LOCATE THE DBF FILE FOR QUERYING Dim path path = "C:\GPS_data_collections\Packets_Outgoing\Support_Signs_Data_Collection_2011\MUTCD_Code.dbf" Dim pDS Set pDS = Application.CreateAppObject("RecordSet") pDS.Open(path) pDS.Find("MUTCD_CODE") pDS.MoveFirst Do While Not pDS.EOF Dim Description, ObjectID Description = pDS.Fields("MUTCD_CODE").Value ObjectID = pDS.Fields("MUTCD_CODE").Value objEFPageOneControls4("List1").AddItem ObjectID, Description pDS.MoveNext Loop pDS.Close Set pDS = Nothing End Sub
Sub Save ....code to Save or Update the dbf Call PopulateMUTCDCodeComboBox End Sub Sub PopulateMUTCDCodeComboBox Dim objRS4, objSelLayer4, objEFPageOneControls4, objEditForm4 Set objSelLayer4 = Map.SelectionLayer Set objRS4 = objSelLayer4.Records objRS4.Bookmark = Map.SelectionBookmark Set objEditForm4 = application.map.layers("Supports").forms("EDITFORM") Set objEFPageOneControls4 = objEditForm4.Pages("page2").Controls objEFPageOneControls4("mutcd_code").Clear MsgBox "The MUTCD Code List is Updating, Please hold on!" & vbnewline & "The combobox will populate shortly", vbExclamation, "MUTCD Updating" Dim path ' Desktop path path = "C:\GPS_data_collections\StreetSign_Collection_ArcPAD\Packets_Outgoing\Support_Signs_Data_Collection_2011\MUTCD_Code.dbf" Dim pDS Set pDS = Application.CreateAppObject("RecordSet") pDS.Open(path) pDS.Find("MUTCD_CODE") pDS.MoveFirst Do While Not pDS.EOF Dim varMUTCDCode varMUTCDCode = pDS.Fields("MUTCD_CODE").Value objEFPageOneControls4("mutcd_code").AddItem varMUTCDCode, varMUTCDCode pDS.MoveNext Loop pDS.Close Set pDS = Nothing End Sub
If I read your code correctly it would be easier to use these requests: objEFPageOneControls4("mutcd_code").Clear objEFPageOneControls4("mutcd_code").AddItemsFromTable path, "MUTCD_CODE", "MUTCD_CODE" and not do any looping at all. Rolf
objEFPageOneControls4("mutcd_code").Clear Dim path path = "C:\GPS_data_collections\StreetSign_Collection_ArcPAD\MUTCD_Code.dbf" objEFPageOneControls4("mutcd_code").AddItemsFromTable path, "MUTCD_CODE", "MUTCD_CODE"
